Question about HP Photosmart 2610 All-In-One InkJet Printer
HP printer all in one
i need power supplies for all in one photosmart 2610xi.please
  • 1,601 Answers
Re: HP printer all in one
Here is where to get one from HP. I would strongly advise to get an OEM product.
Posted on Nov 12, 2007
0 characters
3 Points
HP Photosmart 2610xi is printing but it does not keep the left margin aligned - it typically floats progressively to the right but sometimes wanders back and forth. Also about mid-way through each line...
You need to clean the encoder strip, that's the clear strip that runs behind the carriage assembly, you can clean it with a Q-tip damp with alcohol, the strip is fragile so don't press too hard. If you look with a flashlight you should see the area that needs cleaning.
Dec 31, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Can't scan a photo
Try and download the drivers for Vista on the HP website. This is the link :⟨=cs
Dec 31, 2008 | HP Photosmart 2610xi All-In-One InkJet...
I need to no whats compatible to add my printer hp photosmart2610xi all-in-one
Step 1) Type HP.COM into the Google searchbox, and click on
to start the search.
Step 2) Once you are on the HP website:
Type HP PHOTOSMART 2610xi into the HP searchbox
and click on to start the search.
Step 3) You will then see a picture of your printer. Click on the
the first line beneath the picture, related to SUPPLIES
Step 4) You will then see a list of products compatible with your
Hope this info helps you out. Please take a moment to rate this solution, by using the rating system below. Thanks.
Jul 22, 2008 | Printers & Copiers
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Updating a printer with Vista.
Hp has a new driver package available from its website. However, it's best to install the basic printer driver under vista, as the software package does not work properly (even though it says it's for vista).
Oct 21, 2007 | HP Photosmart 2610xi All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
