Dishwashers Logo
A
Anonymous Posted on Jul 27, 2014
Dispenser door will not open
Modelnumber 1677991
Ronald Rissel
Level 3:
Master:
  • Kenmore Master 715 Answers
  • Posted on Jan 20, 2015
Ronald Rissel
Kenmore Master
Level 3:
Master:
Answers
715
Questions
Helped
259060
Points
1075
Do you have calcium build-up on the lid or catch? Is the spring that makes the lid spring open broken? Are you placing pans or large plates up against the front of the dishwasher that is holding the lid shut? In most cases, question #1 is the cause. Mix some Lemi-Shine powder in some hot water and use an old toothbrush to clean it off. You can also use "CLR" to clean it off. Or you can just buy some Dishwasher Magic to clean out the calcium throughout the dishwasher.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Ice will not dispense through the door. What part do I need to fix it?
https://www.repairclinic.com/PartDetail/Kenmore-Refrigerator-Ice-Bucket-Auger/WP2198574/920447?modelNumber=106.56662500&fromRepairHelp=True&ss=a4b6d698917
Detergent cake left in dispenser after wash cycle
Has the dispenser door open at end of cycle. If dispenser door is open but not fallen down to the tub means most likely the water arm pressure is not good enough to get flush down to the tub.
Door not open means dispenser failure or control board not giving power to dispenser at right time. In some cases dispenser door is stuck with harden earlier soap so it cannot open completely in the cycle.
Why not when opening the door at end of cycle, listen to dispenser area to see the flapper opening while you are opening the door. That means dispenser not opening properly in the cycle.
This issue is a hard solve sometimes. Don't wont to spend the money, then just use the tablets and through them in the tub in the beginning and say good bye to dispenser.
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
1helpful
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
Kenmore mod. 106 water does not get to ice maker and when pushing despenor no rotation of ice out door
Hello Jim,
Sorry it has taken me a while toget back to ya i just got.
So on your refrigerator it very likely is the switch forthe cradlethat ya push to dispense ice and water through the door.
Unfortunitly modelnumber 106 asyou have listed is only the source number of whom your Kenmore was made by. Typically the full model# that does start with 106 willbe on a label on the ceiling or side wall of the refrig. section inside of it, reply with complete model number please and i will be able to help ya disassamble the door dispenser as well as provide you with part numbers and such
Thanks for using FixYa.Com
GENE
FROST BUILDS UP BETWEEN DOOR ICE CHUTE AND ICE MAKER AND IN FRONT OF ICE MAKER AUGER. MAYTAG MSD2756GEB
The door is probably not shutting all the way because of a broken hinge or hinge bracket or the solenoid sticking. You'll have to look to see what's wrong. Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram and parts list of your dispenser. Check the spring and other related parts. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MSD2756GEB&productCategoryId=0165000&brandId=3048&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00008&componentDescription=FOUNTAIN&documentId=M0404275&backToLink=Return%20to%20Sub%20Components%20list
1helpful
2answers
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
