We have a sharp AL1631 copier and the misfeed paper light will not go out even though we have removed all the paper that was jammed.
We have read that perhaps a sensor flag has been disturbed, but we do not know what we are looking for in order to make sure the sensor flags are "moving freely".
Please can you help us.
there is proberly an sensort that has not been reset or a smalll bit of paper still in copier start from the begining off the process and pull the paper tray out and check to see if the papaer is set properly in the tray then follow the path through the copier to teh drum section and check the sensor arms are all free to move then to the fuser (HOt Section) make sure there are no small pieces left inside the path of the paper open all doors and check they close properly.. if you have checked all this correctly the light shoul go out on reset and you will be fine if not there is sensor not moving freely and yuo need to check again..Good Luck A
Was this helpful?
Yes
No
Popular Solutions for Sharp AL 1631 Grayscale Copier
sharp al-1631,no idiot lights showing, new cart. installed, it doesn't copy anything. unplugged,...
(More)
SHARP AL-1631,NO IDIOT LIGHTS SHOWING, NEW CART. INSTALLED, IT DOESN'T COPY ANYTHING. UNPLUGGED, RESTARTED, TURNED OFF, TURNED ON AGAIN. NOTHING.SLIGHT, VERY QUIET GRIND OF INTERNAL BINDING OF GEARS AS IT GOES THRU THE FEEDING PROCESS. ANY HELP WOULD BE APPRECIAIVE. cHUCK
Instruction Sheet on how to use a Philips remote control type Universal SBC RU 644/05 on a Sharp...
(More)
Instruction Sheet on how to use a Philips remote control type Universal SBC RU 644/05 on a Sharp LCD colour TV Model LC-32P50E Aquos Serial No.511628771
