Question about Plumbing
Not pumping...not tripping breaker...making an electrical noise like it is trying to start.. a buzzing noise for a few seconds and then stops without tripping breaker...turned off breaker...
  • 65 Answers
Remove pump and check for something stuck in the impellor assuming that it has one. You didn't say what you are working with. So, sounds like something clogged or stuck in what ever it is that you are pumping. If that is not the case then you have a bad pump motor.
Posted on Jun 30, 2009
Indesit is70c
its a saftey device, called a "thermodisk". It's purpose is to turn off the heating coil or stop gas flow in the event of over heating. If the thermodisk is bad, trying to over ride it (trying to get it to run) will trip the breaker. Its about 10 bucks and easy to replace.
Dec 31, 2013 | Dryers
When turned on you can hear a buzzzing, like electrcicity going into the pmp then pump heats up and trips its saftefy switch. Motor does not turn.
I am assuming that this is not a brand new installation. If it is, go to http://www.femyers.com and download a manual for your pump.
If the pump has worked properly in the past, what seems to be happening is that the motor is locked up and the built in thermal protection is correctly protecting the motor. Or if by "safety switch" you mean the circuit breaker is tripping, then the following still applies.
The pump impeller may be jammed with debris, or the motor bearings may be worn out, causing the rotor to jam and stop rotating. Also a possibility - the seal between the pump and the electric motor has failed, allowing water into the motor and causing a short circuit which trips the breaker.
It is probably time to call the repairman, or replace the pump. Don't keep trying to turn on the motor; it will not fix itself and you may make things worse.
Remember, these pumps must be primed with water first before first use. Look in the Operating Instructions manual.
Mar 24, 2013 | Myers Pump QP10-3
Siemens breaker just for overhead lights in bathroom and hallway Why does it buzz for a second then TRIP off?
You say the breaker supplies power to just one or two lights? And no outlets, fans, attic circuit? Map out all affected electrical boxes.
Move wire from suspect breaker to another same-size breaker and see what happens.
Move wire from the other breaker a to newly installed breaker, to check if breaker is main suspect.
Open each switch and outlet box affected by suspect breaker.
Disconnect power at light switch, and see if breaker still has problem.
Unplug all things from outlets on circuit.
One by one, check each electrical box for burned wires and loose wires.
Use nose to smell for burned condition.
Add a comment and update as you progress through troubleshoot.
http://waterheatertimer.org/Troubleshoot-household-electricity.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 22, 2012 | Electrical Supplies
Pool pump motor noise/hum would come and go, noise was not constant nor continuous, every few seconds would go from high to low sound but volume would seemed constant. was not an extraordinary noise and...
The problem is the starter capacitor on the back or top of motor depending on make. The capacitor is round and black and about 3 inches long and the diameter of a half dollar. it will have 4 wires with quick disconnects on them, unplug and replace capacitor and put wires back on the same way they came off old one. as far as the noise, the bearings are starting to wear and can be replaced when you get tired of the noise. you will have to take it in to have the bearings replaced.
Aug 31, 2011 | Emerson Pool & Spa
Pump makes buzzing noise but does not run. shortly thereafter it trips circuit breaker.
The first thing to check is if the pump is siezed up and stopping the motor or if the motor is bad....
Take the motor off of the pump and check to see if the pump will spin... then check if the motor will run without the pump onit...
This will tell you if you have a bad motor or a bad pump...
heatman101
Feb 21, 2011 | AO Smith Centurion 1081 2 Hp Standard...
Cadet 5' x 36'' Whirlpool white 2771.018W. Bath is filled, turn on, buzz for a few seconds stops and dosen't do any thing. After a few minutes buzz again as if it wants to turn on but nothing.
From the sound of it the pump has seized and the thermal breaker is tripping causing the off and on buzzing sound. The problem could be in the motor or the pump attached to the motor. The easiest way to check this is to pull the pump/motor assembly out and check the rotation of the impeller. The impeller should spin freely with no drag. Most pump/motor assembly have a screw slot in the back under a plug or just open in the middle of the back of the motor. In some cases this test can be done without removing the pump/motor assembly. If the motor and pump do not spin freely, puchase a new pump and motor as one unit..
Sep 06, 2009 | American Standard 2771.002.021 Cadet 5' x...
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Goodman Condenser - Heat - Buzzing Noise every 60 seconds
It could be your compressor trying to start but not being able to do so. It shouldnt happen that often but in cold temp the overload protector may cycle that quickly. I reccomemnd to have it checked to salvage the expensive compressor.
Dec 24, 2007 | Goodman CLQ36AR49 Air Conditioner
Plumbing Logo
230 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
