Question about Acer Aspire 3004WLCi Notebook
Will not use the cd rom drive as boot for repair
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    explain further please.
  • 192 Answers
I suspect you have the boot order in the bios set up to boot off the hard-drive first. You need to change this so the computer will attempt to boot off the CD rom first before it attempts to boot from the hard-drive. I'll try to describe how to do this. While the computer is booting push whatever key it indicates you need to in order to enter setup. Often this is the F2 key. Use the arrows to move up or down the list to an entry that will say something like "boot order". Usually you can select this by hitting enter. Then follow the instructions on the screen to move CD rom to the top of the boot order list. This may involve using the page up and page down keys. Exit and save. This usually involves using the Esc key. Once you set this it will always check the CD rom for a disk before it tries to boot from the hard-drive. It will still boot like normal if it doesn't find a boot CD in the CD rom.
Posted on Jun 30, 2009
Labtop won't turn on
Turn on, hold F8 button down until boot menu appears. Download Norton Boot Recovry to disc from another computer. Install in ur CD/DVD drive. Boot ur computer. Or install ur operating system disc in cCD rom drive. Reboot computer, hold F2 button down, modify BIOS boot sequence so CD Rom in 1st boot device. Boot computer, repair or reinstall operating system.
Sep 08, 2012 | Toshiba Satellite L355D-S7813 Notebook
Bootmgr is missing
Take one bootable windows cd rom , insert the cd rom in cd rom drive, restart your Laptop , go to bios setup and select boot from cd rom after then save and exit . your Laptop will boot from cd rom . it will take some time , when you will see action prompt , select R ( if your bootable windows cd rom is SP2 ) , select D ( if your bootable windows cd rom is SP3) . if you select R you will be prompt repair consoul , format C:\ then instal windows SP2 . if you select D , you will be prompt delite partition , delite partition C:\ after then select C to creat partition and install windows SP3. either of one windows install like that and problem will be solved. n.b. if you don,t have cd rom drive pls collect USB cd rom drive.
Jul 30, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
I have tried to run windows on it but its not booting from the drive instead it restarts over and over
If you want the system to boot from a cd, try this:
As it boots hit F2 then go to boot options and set the cd rom drive so it boots before the hard drive.
Or you can hit F12 on boot with the Windows cd installed and select the cd rom drive to boot from.
If you are saying you want to repair the constant restarting you can boot from the windows disc as stated above, then select repair windows using recovery console. Then type FIXMBR . You can also try typing FIXBOOT. That "may" fix the boot loop your machine is stuck in.
Sep 24, 2011 | Dell OptiPlex GX240 PC Desktop
My computer wont start...it keeps saying missing NTLDR?...what do i do?
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Sep 20, 2009 | Computers & Internet
Booting probs
go to boot sequence in the order
CD/DVD
Hard disk
others
Apr 23, 2009 | Compaq Evo N410C Notebook
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
Acer aspire 3680
You need to boot with your windows vista cd and select repair install. This will reinstall the windows files, including the ntldr file, leaving your data intact. Make sure you only do the repair install, if you do the full install, it may wipe your data.
Thanks and please take a moment to rate as fixya.
Nov 07, 2008 | Acer Aspire 3680 Laptop
Pc wont boot up after reformat.
After format your computer will not boot if don't have the Sys files on it. Try to put your hard drive back to your computer and start booting with some cd with hard drive utilities like http://www.ultimatebootcd.com/
Sep 24, 2008 | E-Machines eMachines Desktop PC
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 3004WLCi Notebook Logo
262 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
