SOURCE: 'service engine soon' light
HI
without using the scan tool you can do it by disconnected the the battery for ( 24 h) to reset it or to ( 5 m) to reset the service engine light but the fault sty in the memory
WITH MY BEST WISHES
SOURCE: service engine soon light 04 nissan titan
make sure the gas cap is tightly sealed. Inspect the gasket on the gas cap
SOURCE: Service engine soon lights on (Nissan Quest 2007)
This is most likely the O2 Sensor however, that light may also come on for a vacum leak or anyone of a number of other sensors. Take the vehicle to Auto Zone and ask them to use a code reader on it and tell you what the code is for. If the code is for O2 sensor as I suspect the part will cost about $40 and take maybe 20 minutes to replace your self. ($40 for part + 5 to 10 for the special socket) If it shows anything else you may want to take it to a mechanic to have the vehicle diagnosed.
SOURCE: nissan frontier 2002 failed emissions test with
CODE PO447 EVAP CANISTER VENT CONTROL VALVE CIRCUIT OPEN.POSSIBLE CAUSES. 1.HARNESS OR CONNECTORS THE SOLENOID VALVE CIRCUIT IS OPEN OR SHORTED. 2. EVAP CANISTER VENT CONTROL SOLENOID VALVE.
SOURCE: 2005 Nissan Altima 2.5 engine.
you need to replace crank position sesor.about 50.00 and an hours labor(pain in the *** wait till you see where they put this thing!)very common falure on these....should have come with a replacement in the glove box when they sold them new!
