Question about AmcorAire UCHW-H24AF2 Split System Air Conditioner
Amcoraire / aos241hx / code p8 / unit shut down will not restart
Compressor unit was shutting down / code p4 / checked pressures (ok)but would reset in about 10 - 15 min and come back on / now code p8 / unit will not restart
I have the same problem when cooling at 72 degrees and unit runs all night without the compressor kicking in. I flip the breaker turnibg the power off and after a coupleof minutes I hear a click in the switching valve and the unit will restart when power is restored.
Posted on Dec 07, 2009
For all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Posted on Jul 13, 2009
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Hi,i have split air condition unit AMCORAIRE the model is AOS241HX and an inside unit i se code P7 and compresor and condensan fan doesent start on
P7- communication problem between indoor and out door. Check power in out door. if there repair/replace out door PCB> If no power in out door, replace indoor PCB.
Jun 01, 2011 | Heating & Cooling
Amcoraire minisplit A/C Model #AOS121HX Not cooling/heating P4 and p8 error codes After having the A/C head unit previously installed. I had to remodel and relocate the head unit to another...
P4 is a overheating compressor code in the outdoor unit. You probably still have a leak. Have your brother remove the remaining freon and pressure/leak test with a charge of nitrogen. I'f its leaking out this fast you should be able to find the leak with a soap solution. Once you've found the leak, pull a vacuum and flush with nitrogen before recharging the unit.
Sep 26, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I have a 24 ton mini split, that has never worked correct. It used to blow cold air, but only for a little while, then it set error codes including p4, and p8. The heat functioned used to work ok. Now it...
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor. Due to non condensable gas/over charged/condenser dust blocked.
For non condensable gas, remove gas and flush out and then recharge gas./remove over charged gas/clean condenser coil
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hi I have an Amcoraire aos121hx mini split, it worked great last summer and this past winter. Haven't used it for a few months and now when I try to get cold or heat it gives a P8 error?
Check the gas pressure by depressing the Schroeder valve under the cap where the gas pipes enter the outdoor unit. you have probably lost some or all of your gas
Apr 21, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jul 02, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
AmcorAire  UCHW-H24AF2 Split System Air Conditioner Logo
893 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
