Question about Dishwashers
Small leak from bottom corner of door. Found small piece of gasket missing. Can I get a part number and instructions to replace?
  • 109 Answers
Yes just go to the website of the diswasher that you own and look for prouduct or parts list
Posted on Jun 30, 2009
Water leaking from door
Without knowing the brand of dishwasher you have, generally this type of leak
occurs when the corner seals to the door have failed or are completely missing.
They are usually small black rubber affairs in each corner at the bottom of the door
or semi clear plastic. They pull out, and occasionally children remove them.
Mar 19, 2011 | Dishwashers
Water leaking comming from the bottom/center of front door. The leaking start as soon as the washing phase kicks in. Is there a seal issue? Found a plastic strip (about 1.5 inches wide) along the bottom of...
That gasket is supposed to look like that. Use less soap and/or replace that gasket. It is very easy to do but pay attention to how the old on is placed. There is a small notch that has to be placed right.
Dec 18, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Need instructions on how to replace door gasket of dometic 2310 rv refriterator.
loosen all the screws located in the middle of the old door gasket, remove the old gasket. starting at the top of the door; wedge the new door top gasket corner into one of the gasket frame corners at the door top and, screw it down to secure; because the gasket will not be wide enough; use a hairdryer to gently stretch it to the other top corner and, secure that corner then : using the hairdryer continue to stretch the gasket downward and, fit the rest of the door gasket into both of the remaining bottom corners then: slip the rest of the gasket under the gasket frame and, tighten all the gasket frame brackets.
Jul 15, 2010 | Refrigerators
Dishwasher is leaking out of the front right bottom corner. It spurts out while it is running. I took the front panel off and could see that where it is coming from but dont know why it is all of a sudden...
most of the time when it leaks from the front door it is going to be from a corner. most every time the front door gasket is replaced to solve the problem. I have found that the gasket on my dishwasher last about 2 years before needing replaced. I clean the white hard scale that builds up on gasket frequently
Jun 17, 2009 | Dishwashers
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
Water leaking from bottom of door during wash cycle
this will more likely be your door seal open the door pull your seal so u can see inside and feel around as u look u will more than likely find a hole the water looks like it comes from somewhere else but it will be from the hole in the door seal seen this with hundreds of washers m8
Aug 26, 2007 | Kenmore 43142 Front Load Washer
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
