Question about Motorola Mobility MOTO W755 Cellular Phone
Backlight stays on constantly, running down battery
Try going under menu setting tools display settings and see if the backlight setting is on always on. If it is click a different time length you would like. Let me know if that helps!! Have a good day:)
Posted on Jul 19, 2009
My benz won't stay running unless I hold the gas down constantly
sounds like a fuel pressure issue check fuel filter lines& linkage
Sep 04, 2012 | 1992 Mercedes-Benz Mercedes Benz 300 Class
John Deere LX188 17hp Kawasaki eng. Battery light constantly on; PTO for mower intermittent; will shut down after running for about an hour(battery discharge?). Suspect voltage regulator. Can't...
I have same problem with my lx188 battery light stays on and will run fine at idle, then I can mow for about 15mins then it powers down and run rough, and battery light dims down.
???? Is it the voltage regulator ?
May 06, 2011 | Garden
Hi, my bb9000 consumes battery very fast please advice what should i do in this regard?
Instructions
    • 1 Turn off your wireless and Bluetooth when they are not in use. If you leave your wireless settings on, your phone is constantly looking for a wireless connection, even if one isn't readily available. This eats up battery power. Touch "Manage Connections" from your home screen and select "Off" for wireless connection. Then turn your wireless on when you know a connection is available.
    • 2 Close applications when you're finished using them. Leaving applications running uses memory and battery power, especially if those applications send you frequent notifications, like Facebook. Once you're done using an application, use the Blackberry button and select "Close" at the bottom of the menu to close the app completely and avoid notifications until you open the app again.
    • 3 Use your applications wisely. If you're running short on battery life, it may not be a good time to run Google Maps or other applications that use a lot of battery power. In general, battery-consuming applications are those the need a constant internet or data connection and cause you to receive frequent notifications.
    • 4 Change your vibrate notifications so that they occur less frequently, and use audio notifications when you can. Vibration actually uses more battery life than a ring tone. While you may need to put your phone on vibrate when you need to use your phone discreetly, shortening the amount of vibration notifications you get can conserve battery life. Choose "Options" from your home screen, and then "Sounds and Ringtones." Choose "Ringtones" from the drop down menu and select the type of ringtone you want. To decrease the volume of your vibration -- and therefore the power you use -- press the volume buttons on the side of the phone when the phone is in vibrate mode.
    • 5 Decrease the backlight timeout, which keeps the keys on your Bold lit for a specified amount of time after you stop using them. The shorter the timeout, the less battery power you'll waste. Visit "Options" from your home screen and then choose "Screen/Keyboard." Adjust the backlight settings so you only have three to five second before timeout and the backlight shuts off. You can also use the settings to dim the backlight to use less power.
Read more: How to Optimize My Blackberry Bold's Battery Life ' eHow.com http://www.ehow.com/how_8087565_optimize-blackberry-bolds-battery-life.html#ixzz1HLj9WRhr
Mar 22, 2011 | RIM BlackBerry Bold 9000 Smartphone
Mercedes-Benz 2002 E270CDI Auto. Constant problem with battery running down. Battery replaced. Alternator regulator replaced. Possible drain whilst stationery as all appears to work OK when running. Any...
Check for hidden things that may be staying on. Trunk lamps, under hood lamps, and lighted visor mirrors, as well as glove box lamps are many times the culprits.
Mar 10, 2011 | 2002 Mercedes-Benz E-Class
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Front key pad stays lit all the time on my wifes envy2 runs battery down
Go to your display setting. Then go to backlight, then click keypad. And then you can choose how long you want it to stay lit up. Hope I helped
May 23, 2009 | LG enV VX9900 Cellular Phone
Screen stays dark
How long have you had your computer? Mine has been doing this. The battery has died out over time, and now I think the adapter is too. It's kind of kinked near where it plugs into the computer (probably from the weight of the chord constantly being pulled down). It just gets a bad connection, a little less power, and goes dim like that. If I readjust the connection and turn off/turn back on the computer, it usually comes on bright again. But I ordered a new battery
Dec 17, 2008 | Dell Inspiron 1200 Notebook
V3i
hi..ur motorola v3i is defaulted with 7 to 10 hrs of battery life only...o save more power...
  • Keep the brightness on the screen to a minimum. You can also adjust how long the backlight stays on without input from the user.
  • Turn off the Bluetooth when not in use. Bluetooth is a big battery draw.
  • Disable incoming beams so that the phone isn't constantly "searching" for infrared partners.
  • Completely close non-essential programs. When you run an application, it does not shut down completely when you "close" it. It is simply minimized. Go into the Settings to completely shut down any programs you are no longer using
  • also u cud get a car charger so that u cud be sure not to run out of juice..
    Thanks for using Fixya
    Aug 22, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    YP-T9 constantly charging?
    if you recharg it too much it could be wearing down, I'm guessing. unless oyu just got it.. you should take ti back because that's just messed
    Jul 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
    Motorola Mobility MOTO W755 Cellular Phone Logo
    111 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
