Question about Panasonic sa-ht800V Home Theater Audio System SA-HT800V System
Cannot get tv to play through speakers with cable dvr unit
  • 55 Answers
Not enough info but... have you checked to see if your audio is output on the dvr and input on the reciever? also selecting the right audio on the tv menu might help... there is also a chance you might have to route the audio stright from the tv to the audio reciever instead of going from the dvr.
Posted on Jun 30, 2009
Use your audio out left and right to the in audio left and right and use the aux on the receiver...should work for you..turn off the tv speakers in the menu..you will have to use both remotes your tv for turning channels and the receiver remote for the volume...works for me hope this will work for you....ezrider01
Posted on Dec 08, 2009
Why can't I record on my DVR?
Check all your connections and configuration between decoder to DVR and TV. I find it is more practical to use the DMI connectors for this purpose. Between my LG TV, LG DVR, LG Blue Ray Player and Decoder I use 3 DMI connector cables. Ideal for me because my TV has 3 DMI points, I just connect each of 3 items to TV via a DMI cable. Now connect decoder to DVR via video-audio cable (red-white-blue). This setup allows each unit to be used individually (i.e. tv viewing, recording, blue ray playing and when recording live TV the TV can be switched off while recording. Just remember to select the appropriate DMI connected unit on your TV remote (on "input" button).
Feb 16, 2016 | Panasonic Televison & Video
How do i hook up mono tv with eterxnal speakers with a dvr box
If the DVR has RCA-type connectors, yellow to yellow for picture, and white to white for sound. Tune tv to line input.
If the DVR supports outputting everything on coax, use a piece of coax cable, and tune tv to channel 3.
Your coax cable from wall has to go into DVR first, then out to tv.
Aug 26, 2014 | RCA F32650 32" TV
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
How to hookup dvr cable hd box to dvd player with surround sound
If you have HDMI on the dvr and the tv use this cable connection this will handle audio and the video at it`s best, if you do not have HDMI, use the 3 component video outputs to the tv and a digital audio connection from the dvr to the tv
Feb 01, 2009 | Audio Players & Recorders
No RF signal output to the TV through the coaxial cableIs, is that normal?
Yes. This unit only relays the TV signal...the coaxial output can't be used to watch DVDs or play the DVR, all operations are done via the component, composite, or S-Vid outputs. The coaxial simply passes the TV signal out as in from cable TV to DVR and from DVR to TV. If you still do not get an RF signal to pass through th unit, check the cable to make sure the wire is not bent or brocken on either ends.
Jul 14, 2008 | RCA DRC8030N
RCA DRC8030N
These units have flaky TV tuners. Try connecting the coax cable (the one with the cable television signal or antena) to the back of your TV first and from there take the output to the input of the DVR. By doing this, you will beusing your TVs TV tuner vs the DVR's flaky one.
Mar 13, 2008 | RCA DRC8030N
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Panasonic recorder
Have you checked your cables? Start resetting one unit at a time until you isolate the culprit. Don't forget the simple unplug all units to let them reset. .
Panasonic DMR-EH55
Motorola 6416 DVR
Sony STR-DA5000
27 analog tv!
Sony 5 Disk DVD Changer
5 speakers
PC connected
You think I have fun when something hiccups? A software snaffu? Bad a/v cable? Loose speaker wire? By the way-my online support is getting better and better. Charter cable has live chat, as does Sony and Motorola. Good luck. Also, I can't think of a single setting I've changed with the Panny. other than assigning digital audio out settings. DEcoder setting? Your Panny?
817-230-4017 if you haven't fixed it.
Dec 09, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
424 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
