Question about Mitsubishi WS-65615 65" TV
Power light blinking
When there is a breakage in power the TV will not automatically come back on, instead the power light blinks, sometimes up to several hours, before the picture returns. Today there was no power shortage but the power light began blinking on it's own. How do I solve this problem? The model # on the back of my TV says WS 65513 but that # is not listed below.
Thank You
  • Anonymous Nov 23, 2007
    I am having the same problem for the second time with my WD-65613. I had it repaired for the same symptom aprox. one year ago. It cost $300 dollars. The green indicator light on the front blinks rapidly and will not go off. The television will not power on, manually or with the remote. I have tried pushing the reset button and unplugged the televison nothing helps.
  • ortco707 Feb 02, 2009
    green light flashing tv will not turn on how do i fix
  • Mitsubishi Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
    Problem Solver:
  • 9 Answers
Using The System Reset Button
If the TV doesn't respond to either the remote control or the front panel controls or will not power off, press the
SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a
The TV will turn off and the green LED will flash quickly for about one minute. When the green LED stops flashing,
you may turn on the TV again. The changes you made while the TV was most recently on, before you used the
SYSTEM RESET button may be lost, however, the changes you made previously are not lost. Only those changes
since the last power On may be lost when the system reset button is pressed. All other settings are retained.
Posted on Oct 10, 2009
Sony bravia KDL46-V3000 inch led Tv red light blinks 6 times???
It means you do have a LCD panel back lights problem, in most of the case, a defective back lights inverter could be the cause.
Jun 28, 2017 | Sony Televison & Video
Keeps turning off
Everytime I worked on this set I have found bad connections in the power supply or on one of the inverter transformers
Dec 31, 2013 | Philips 42PFL5603D 42 in. LCD HDTV
My Sony Trintron's LED Light blinks 9 times when I try to turn on the set
  1. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). If you wish to get more details about the blinking codes to Sony brand TVs, check this link. Pull up older posts there.
Mar 04, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung txr3079whx/xaa 5 blinking lights
5 blinks to Samsung indicates a fault in the main power supply output voltage.
Jan 23, 2013 | Samsung Televison & Video
Green power light want stop blinking
Problem is with one of the circut boards in the tv, It will have to be replaced.
Oct 21, 2012 | Sanyo DP19647 19 in. LCD TV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Do you get lights? are they blinking? The number of blinks will tell you what is wrong if you go to the manufactures site and pull up the manual. (It may be a combination of lights instead of blinking lights)
Check for:
Bad bulb-check to see if the little wire inside is whole, just like in a lightbulb, look for cracks near the base, or any other sign of breakage.
bulb- inserted improperly?
All panels and doors must be on, and the screws in, for most projectors to do anything..
Check the cord, you should get at least one light if the cord is good.
Jul 05, 2010 | NEC LT 260 Multimedia Projector
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WS-65615 65" TV Logo
373 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
