Question about Garden
Mower deck will not engage.
Stopped mower, shut off deck. Remained on seat, engine never stopped running. Pulled deck engage back on after about half a minute. Nothing happened.
Checked with the mower running. The drive pulley for deck is not turning. The mower drives fine. It's 2005 Poulan Pro 24 hp with a 48'' deck.
The deck switch is an electric push/pull switch. Mower stopped charging battery three weeks ago. Any correlation?
Chuck
  • 127 Answers
You have sheared off the keyway either on the mandrel or pully on the engine
Posted on Jun 30, 2009
I have a Husqvarna GT54LS riding mower with a B&S engine. It starts and runs well. When I engage either the mower deck or the differential lock, the engine stalls. What can be the problem?
occupant switch on seat thinks there's no operator in seat with blades engaged , so safety ckt shuts engine off
seat switches go bad sometimes
Sep 14, 2016 | Husqvarna Garden
Mower starts and runs fine but when button pulled out to engage blades the engine stops hope you can help Paul
your mower deck maybe seized or the safety switch malfunction check if you can turn your deck by hand if yes then find safety switch for deck hope this helps
Mar 30, 2015 | Garden
Mower blades stopped
You aren't giving much information. You haven't said what manufacturer or model of tractor you are using. But there are a few issues that can cause this. There are safety switches that will shut down the blades under certain conditions (like if you get off the seat). There may be an electric PTO that engages the blade belt that may have failed (or the switch for it), Or the blade belt may have broken or jumped off the engine crankshaft pulley or deck pulley.
Aug 24, 2014 | Garden
Have a j,d gx345 took car off ,cleaned cranks up and runs fine,but when I engage deck dies?
were you sitting down in seat at the time ? cus this model has a safety system that shuts engine off if mower is engauged and no rider is in seat , if so then you got a problem with your seat switch sometimes they get unplugged or pulled loose when fueling it up
May 17, 2014 | Garden
My tractor keeps shutting off when i engage the mower blades
It would depend on what model, but could either be a deck drive problem or safety switch. With tractor off, I'd check the blades for free movement with no binding. If this is ok, then I would suspect the seat switch. The mower will not run with the deck engaged, and no operator present. It could be the seat switch is not making, so when you engage the deck it kills the motor. Test switch
Aug 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Riding Lawn Mower Completely Dead
Sounds like the battery gave out.
If the battery test good then you most likely have an inline fuse that is blown out.
May 05, 2010 | Garden
My husqvarna zero turn mower has an auto safety shut off. I have isolated 3 (Brake, Left control level, and Right contol lever)trying to see which one was faulty, but I'm not sure where to go next. When I...
There should be a switch under the seat. The system is designed to stop all functions if no one is setting in the seat. I believe the seat switch has failed.
Check it out and let me know.
Regards,
Jul 20, 2009 | Husqvarna Zero Turn Mower Z5426
Steped off mower while still running. Now it will not restart, has good gas flow and spark
check the safety switch under the seat, it shuts off the mower when you get off. get a piece of wire, cross the wires, see if it starts
Jul 04, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
636 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
