Question about Kwikset Professional Door Lock installation Kit
Problems changing a doorknob
Our door handle broke off of our entrance door knob and we are trying to replace it but we can not get the door knob apart to remove it from the door so we can replace it. how do we pull the old door handles apart
  • 10 Answers
If there are no visable screws on the inside of the door than there is a cover plate that can be removed by prying it off with a small screwdriver revealing the screws. Please remember to rate my answer
Posted on Aug 07, 2009
I have an old schlage door handleset. It is not the one pictured next to this post but that was the closest pic I could find. It has the exterior handle with key lock which locks/unlocks/operates the...
Hi..Please contact the vendor from you have purchase. and replace door handle set or door knobs (knocker). or you can contact to other for new buy as per your requirement. i hope this will help you..
Mar 14, 2013 | Schlage Plymouth" Georgian Entrance...
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
Sitting room door has closed shut and won't open. Hinges are on the other side and I have removed the handle from my end and it appears that a spring in the inside latch has broken.
Now you can put your standard screwdriver in the hole in the middle of the metal where you removed the doorknob, turn the screwdriver, and now your door will open.
Jen
Jan 21, 2011 | Amerock 3 Ring Knobs - BP1586
Broken door knob. no access to hinges, screws. Rental property!
Take apart a similar doorknob in your house. Use the stem with knob on it and insert into the square hole in the lock--turn!
Feb 27, 2010 | Hardware & Accessories
Bathroom doorknob stuck in locked position.
I will tell you how to fix 'em. Open the Door Knob with a screw driver, gently pull aart the two knobs once open, then look for a long sliding rod, pull one knob away, twist the Knob untlil it is in unlock position, put them back together to test if it slips properly. If it does not, there is something preventing the rod from rotating freely. Try to ensure it rotates freely. Then screw back together :)
Nov 18, 2009 | Hardware & Accessories
Doorknob sticks in 'lock' position-but no real 'lock' feature
If this is the lock part itself,try gradually loosening install screw enough to be able to manuver lock to work and if so slowly tighten as you test each time gradually. Please clarify problem more if need to.
Mar 12, 2009 | Top Knobs M826 Door Pull
Stuck Door Knob with No Access!
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Jan 10, 2009 | Hardware & Accessories
The knob is broken
youve probably solved the problem by now but i would use a spanner or molegrips on the spindle to turn it, fitting a new one would have fitting instructions included.
Sep 28, 2008 | Amerock 3 Ring Knobs - BP1586
Kwikset Professional Door Lock installation Kit Logo
764 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
