Question about Home
The drain was dropped in the sink and we thought it was a scratch but it is a small chip you can feel.  I read about epoxy but is this going to be too thick, being it is a very small
    Problem Solver:
  • 6 Answers
I assume this is a new sink and you are trying to save it. There are several options depending on how much time and or money you want to put into the repair. The simplest is what you mentioned yourself. just be sure to clean the surface completely, you may want to use rubbing alcohol to be sure there is no oil or contaminates on the surface. Be sure the area is completely dry before applying the epoxy. There are several types and you will have to determine which is closest as a match for color and sheen. With that said dip a toothpick into a small drop of epoxy and then transfer it to the desired location. Keep in mind that it will more than likely be higher than the existing surface. Once it has completely dried, 48 hours for a good cure, then take a single edge razor and gently press it to the surface and push it along at a 25-35 degree angle to remove the high spot. You may need to do this several times to get the desired finish.
If you are not happy with this then you can have the whole sink refinished professionally by a number of companies. I have used Bath Crest with good success.
Posted on Jul 04, 2009
Bad processor on my hp compaq
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
The "CPU" or central processing unit, otherwise known simply as "the processor," is the primary "brain" of the computer.
Processors are very finely engineered components that are not repairable.
But replacing a failed processor is an option for the owner of any model Compaq Presario desktop computer.
Just check with HP/Compaq for the correct size and speed of processor for your motherboard before purchasing a replacement.
Turn off the computer and disconnect all cables.
Remove the cover.
Lay the computer down flat.
If there is a plastic hood covering an exhaust fan, remove it by pressing in on the indicated release tabs.
Examine the processor assembly.
The processor is a square chip that is covered by a metal heat sink with fins.
A fan will often be mounted on top of the heat sink; unplug its connection to the motherboard.
Two clips usually secure the heat sink assembly to the top of the processor.
Gently press down and slightly away on the flat end of a clip to release it.
Avoid using a screwdriver to release a clip a slip could scratch the motherboard.
Release the clips and gently remove the assembly.
The heat sink should separate, leaving the processor behind in the chip holder.
Clean the bottom of the heat sink.
Use a paper towel and a dab of solvent cleaner to remove the old thermal paste.
Set the clean heat sink aside.
Lift up the lever to unlock the old processor and remove it from the pin mount.
Insert the new processor chip.
Align the pins on the processor to the "cut off corner" or dot on the pin mount.
The processor should drop into the pin holes easily.
If the processor won't drop in easily, check the pin alignment.
Once the processor is inserted correctly, pull down the lever to lock in the chip.
Apply thermal paste to the bottom of the heat sink.
Apply enough paste to cover the area of the small gray rectangle on top of the processor.
Apply the paste with a spreader made from a piece of flexible plastic.
Spread the paste evenly to a thickness of two sheets of paper.
Check the heat sink mounting alignment and lower the heat sink onto the top of the processor.
Reinstall the mounting clips.
Reattach the heat sink fan to the motherboard if necessary.
Plug in the computer and monitor and boot.
If the machine won't boot or it emits warning "beeps," unplug the power and monitor, and troubleshoot your work until the computer boots successfully.
Shut down again and replace the exhaust fan hood.
Close up the computer and reboot.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hope this helps
Nov 11, 2012 | HP Compaq dc5100 Microtower PC Desktop
Dishwasher is a SAMSUNG - The ERROR message was E5, hose kik/drain issue. Even after removing and inspecting hose, plus flushing drain line, not fixed. It does drain through the hose with wetvac suction.
Hello, tom
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Aug 19, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
My Swanstone sink is sixteen years old and still in very good condition except for a small chip. The sink is a cream color with black and white specks. Is there any way to repair the sink?
You should be able to have a competent repair or restoration specialist from a reputable granite or marble fabrication shop come to your home and fix the problem. If it is a very small chip (less than an eighth of an inch around, my first try would be super glue. Keep in mind the fill will be fairly clear in color, which may match the dark specks, if not use an indelible marker after you smooth the glue to color it black. Use the gel type super glue if it is on a vertical portion of the sink, otherwise use a thinner variety. Clean the chip with sop and water, let it dry then use rubbing alcohol to remove any grease or oil residue. Use a masking type tape to isolate the chip so you have less work once the glue dries. Fill the chip and once the glue is dry, use a single edge razor (Use extreme caution, razors are by nature sharp) to gently scrape, not cut the glue flush to the sink surface. The manufacturers of these sinks claims they are difficult to scratch, but pay attention to your pressure or you might create scratches on the sink itself. Hold the blade perpendicular to the surface of the sink and take your time scraping the dried glue down changing to a fresh blade often. If the chip is in a radius area of the sink, you will have to be a bit more creative and probably use steel wool to remove the excess dried glue. I would start with #000 and see how that works, maybe using #00 to start the process and finish with #000 or #0000 steel wool to match the finish of your sink. If your chip is larger than an eighth of an inch around, I would recommend hiring a repair and restoration specialist from a competent granite fabrication shop to make a color matched epoxy to fill the blemish.
If you have any questions, feel free to contact me, Brandon Wiese - Brandon@StoneRepairman.com - http://www.StoneRepairman.com
Mar 25, 2011 | Swanstone KSDB-3322 Double Bowl Kitchen...
Cut a small line through swanstone granite sink when installing undercount . Fixed with epoxy. Will that work?
It should work, I would imagine it's pretty conspicuous, but you shouldn't have problems with leaking if the epoxy filled the hole completely. I would clean the repair on the outside of the sink with rubbing alcohol, then put a decent amount of silicone to completely cover the repair area to insure no water gets through if there are any compromises in the epoxy.
Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Feb 26, 2011 | Swanstone KSDB-3322 Double Bowl Kitchen...
Small scratches and one burn spot
I'm sorry to hear someone marred this beautiful sink on you. This is essentially an acrylic sink, the same material used to make acrylic soaker tubs. Using any type of abrasive cleaner on this sink is going to dull the finish. This includes baking soda. The liquid auto polish referred to is essentially car wax not an abrasive polish. The car wax contains carnuba wax that will return a lustre to the finish but unlikely to remove the damage you've described. The manufacturer recommends using only non abrasive cleansers. There won't be anything you can do about the burn mark, this is going to be permanent. It could be from heat or possibly something caustic. If the gray scratches in the other sink look like they are on the surface of the acrylic you may be able to get them off. If it looks like the gray is underneath the acrylic finish then you will need to contact Thermocast for an acrylic repair kit for the color of your sink. Hopefully they are able to provide such an accessory. Use a plastic pan scraper and see if you can scratch the gray off the surface. The plastic is softer than the acrylic and will not scratch it. Thermocasts customer service line is 678-445-2022 or email them at sales_support@thermocastsinks.com . Their website is http://www.thermocastsinks.com/index.html
Jul 24, 2010 | International Thermocast Corp Thermocast...
Small chips and scratches
If your sink is porcelain or enamel, you can use a "tub refinishing" epoxy to resurface the sink. The two-part epoxies (that you have to mix together) appear to work much better than the non-mixing epoxies. Make sure that you follow all directions. Also, be aware that anything you use to resurface with will not be as durable as the original porcelain or enamel (so stay away from harsh abrasives). You may want to mix only a portion of the epoxy and retain the rest to fix any issues that develop over time. As long as you don't mix the two parts, they should be good for many years.
Aug 17, 2009 | Home
How to fix a rusted chip in a porclin sink?
to do so correctly requires a tub refinisher who has the right chemicals and epoxys, or you can try the available epoxy diy kits at most home improvement centers
Jun 30, 2009 | Pegasus Technologies Pegasus 36 In....
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
SCRATCHED STAINLESS STEEL SINK
Have you tried a really fine steel wool? I don't know if this would work. I have stainless steel farmhouse sink, front exposed all stainless steel. My contractor scratched it up horribly when he was putting it into the kichen. he fixed it amazingly with a fine steel wool pad. I don't know if your scratch is too deep for that but it couldn't hurt. The scratches on our sink were surface but very noticeable. Hope this helps.
Feb 08, 2008 | Kitchen Ranges
Home Logo
85 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
