I get an F11 code on my kenmore elite he 5t washer
    Genius:
  • 1,269 Answers
The F11 code is from a communication break in the serial link from the CCU to the MCU (from the brains to the washer motor controller). Mostly, the error appears if there is a cold solder or an open circuit on the circuit board. Sometimes, there's a blown or burned part on the circuit board. Checking shorted or open wires at the back panel can fix it. But normally, its an internal component failure. Please visit the link below to fix your machine. This is very helpful.
Click the link
F11 Syndrome
Posted on Jun 30, 2009
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    What does the f11 code on a kenmore elite he3 washer mean
    A bad CCU (main control circuit board) will cause this F11 problem 90% of the time
    Aug 26, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite he 5t the code f21 comes on, the hose is ok.
    This is a Long Drain Issue. Likely that something is stuck in the pump trap. Take off the mottom tree screws under the drum panel. This will remove the drum panel on the front. From under neither you can see the drain pipe trap. Unscrew the trap cap in the from. Clean out all debris and re-install. this should do it.
    Feb 15, 2010 | Kenmore Elite HE5t Washer
    My kenmore elite He 5t wash machine is flashing F
    This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
    Sep 09, 2009 | Kenmore Elite HE5t Washer
    F 11 code
    The electronic control board is damaged. It needs to be replaced. I think its Part#8182237. As of this date, it is on back-order. Check your warranty book on this part, it is highly expensive. It may be covered under a 2-5 yr. part only warranty.
    Sep 03, 2008 | Kenmore Elite 45986 Front Load Washer
    HELP!!
    We've had this problem for about a yr when i finally firgured out how to correct it.
    the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
    How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
    Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE 5t
    Hello
    Please see this weblink here for a ton of info on your problem.
    F11 = Serial Communication Error. Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
    Do this = Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    Check the Drive system for any worn or failed components.
    Please rate this post, if you are happy with my response. Respond back to this post if you need more help!
    Jan 09, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    66 people viewed this question
    Top Washing Machines Experts
