Question about Honeywell Programmable Thermostat Heater
Brivis buffalo 85 with EMS2 would not fire up
The pilot light would light up but could not hold on then die out within a few seconds. It repeats with few more attempt (but the same thing happened) then the fan system kick in blowing only cold air into the house. Please kindly advise of cause(s) and a solution. Thank you in advance.
Hi Long Bob
I am having the same problem. Did you find out what was the cause?
Cheers
Chris
Posted on May 08, 2010
I have a brivis buffalo 85 ducted heating system, from last few days it doesn't come hot air only fan is running. pilot lamp also not with flame. ignation is working. I was turm blue color lid to pilot...
you need a new thermocouple. u can either get one from a plumbing store but the can be a bit fiddley to fit or u can get the proper Brivis one it just pulls out and u put the new one in. then u have to re light the pilot light. make sure u hold it down for at least 45 sec to make sure that it is getting hot enough when u release it it will stay alight then turn gas valve to the on position
May 26, 2014 | Heating & Cooling
Brivis buffalo 85 main burner not coming on pilot light is on fan comes on ???
If the pilot is on the thermo couple is ok. Could possibly be a faulty temperature limiting switch, it may be stuck and just needs a spray of WD40 or similar product. Then again I could be completely wrong.
Apr 04, 2014 | Jandy Lite2 LJ125 Ceramic Gas Heater
Brivis buffalo 20 problems
Potentially bad pilot valve. clean pilot. then report back.
Jun 12, 2012 | Heating & Cooling
Brivis Buffalo 85 loud bang.
short blocked pilot needs cleaning burner blocked needs cleaning
Jun 04, 2012 | Heating & Cooling
Pilot lights up but would not fire up into heating, I have brivis buffalo 85
This is the proper cycle of a furnace and what should happen.
Inducer motor kicks on, it runs for a little bit, about 3-5 seconds, then you should see a bright yellow glow, this is the igniter, shortly after, you should hear a click and the gas should start to flow, almost immediately it turns to a blue flame. Then your igniter should turn off and the blower motor start up.
If the pilot turns on and the gas ignites, then shortly after the unit shuts off, chances are this is your blower motor. It is not starting up, then the heat limit is reached in your unit and the safety shuts it off.
Mar 02, 2011 | Honeywell Programmable Thermostat Heater
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Heating isn't working, can't find the red button to relight the pilot
Many times the knob to turn the gas on on the valve is also the pilot knob. Turn it to pilot and hold it down while you light the pilot. Hold it for up to a minute and release. If the pilot stays on then turn it to on. If not you need a new thermocouple.
Apr 26, 2009 | Heating & Cooling
Heating & Cooling Logo
698 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
