Question about Motorola Spirit HP 2-Way Radio
Buzzing on radio
When we transmit to another radio you hear a buzzing along with the voice transmission
  • david malkinski Nov 09, 2007
    Thanks for the possible solutions. About the frequency thing, how do I go about cking it out.
    Again the buzzing sound is heard on the other persons radio recieving transmission, not on the radio sending transmissionh
    Brigadier General:
  • 6,966 Answers
Initial suspect would be:
1. Loose speaker grill cover or retaining clips of the speaker itself;
2. You are using CTCSS codes for personal communication and your code number is actually a buzz/tone where the frequency is sub-audible (still could be heard by some though barely). The said tone is super imposed on the voice signal which the radio uses to allow reception. The lowest is 1 which is 67Hz. Some Motorola uses A - 77Hz, B - 88.5, C - 97.4 with the highest at G - 136.5. Alternately, other Motorola models uses #s 1 - 38 corresponding to CTCSS frequencies from 67Hz to 250.3 Hz; or
3. Either of the radio is being charged while operating.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 08, 2007
  • Louie  Role
    Louie Role Nov 10, 2007
    Hi again,
    Copy that the buzzing is on the receiving unit which is normal if the CTCSS is enabled and is the cause of the buzz.
    To verify if the CTCSS is the buzz, set both radios to either Channel 5 or 10 and key PTT for a dead carrier (no voice). If the buzz is gone, then you have just confirmed that it's the CTCSS since either channel has no allocated sub-audible tone/frequency.
    Incidentally, CTCSS is also called: Coded squelch, Private-Line,
    PL, Quiet Call, Channel, Guard, etc.
    Should you be interested, the CTCSS frequency sub-audible tone programmed in a Motorola Motorola Spirit HP are:
    Channel CTSS (in Hz)
    1 67.0
    2 77.0
    3 88.5
    4 179.9
    5 none
    6 67.0
    7 82.5
    8 94.8
    9 179.9
    10 none
    Alternately:
    1. constant static maybe be due to the battery may be discharged; when using your radio around computers or electronic equipment, you may hear static or interference from these devices.
    2. a lowpitched beep when you turn on the radio indicates internal error and would require factory service.
    Cheers.
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
Motorola Talkabout MR will not transmit
From reading through your settings, they appear to be identical. Except, I am not certain what Vox 2 is, or B5 0. If the number 2 beside VOX is a setting, you should set it to off or zero. Otherwise, they appear like they should work. (VOX = voice activation, and when enabled will cause a radio to transmit when it hears a sound, voice, etc.)
If you are using an audio device such as an earpiece or headset, be certain you are plugging it in with the radio turned OFF.
Lack of transmit can also be a sign of a bad battery or bad battery connection. You might try swapping the batteries and see if the problem moves to the other radio.
If these are less than one year old, use the number in your user guide to contact Motorola for a possible warranty replacement.
Best regards.
May 18, 2013 | Motorola Talkabout T5700 AA (22 Channels)...
I can hear everyone talk to me but i cant transmit to them,they can hear me key up but no voice to them.i have checked all connections and grounds,still the same.
Mic may have audio wire broken in cord at mic plug wire solder connection.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
notice the numbers on the black plug after you pull it out of the radio.
Sep 12, 2011 | Cobra 29 LTD CB Radio
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
FCC ID: K7GFV300 one of the radios doesn't output sound, or the other one doesnt transmit it. i can hear the little buzz when you press the PTT button
Check your programming first to see if the radios match perfectly. Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/FV300%2001-11-08.pdf
Next, check the battery pack in the radio that is not transmitting. A low or bad battery can prevent a radio from transmitting, as it takes more power to transmit than to receive.
Lastly, check the mic hole to see if it is covered or has debris.
Best regards.
Oct 12, 2010 | Motorola Walkie Talkie 2-Way Radio
2002 Honda GL 1800 Gold Wing CB radio receives but won't transmit
Hi, Ohenry428 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
New CB Radio in 02 GL1800 Won Transmit
cb radio no transmit GL1800 Information Questions goldwingdocs com
Honda GL1800 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://goldwingchrome.com/Manuals/GL1800/Honda%20Goldwing%20GL1800%202003%20Owners%20Manual.pdf
Jun 20, 2010 | 2002 Honda GL 1800 Gold Wing
Voice recognition on motorola t5500
That means that it will Transmit, like pressing the "Talk" button, BUT ONLY when it hears the "Voice" it was "Trained" on. So this is so No-one else could use this unit. With this method. You "Identify" yourself, and after that every-time you speak, the Transmitter is keyed, and the channel is opened and the voice sent, when you stop talking,it goes back to receive, again. Some are less sophisticated, in that they are really a "Sound Switch" and when the unit "Hears" a "Voice" it, switches OFF receive, and ON the transmitter, and Transmits the audio out.
Apr 15, 2010 | Motorola Talkabout T5500 (7 Channels)...
Motorola t5720 one buzzes and you can't hear transmission. It transmits to its partner just fine. It just won't receive transmission form its partner, just a loud buzz
Try trading the batteries between the units and see if the problem moves to the other radio. If so, replace the battery pack. If the problem persists, you have a defect radio, which needs replaced.
Best regards.
Nov 01, 2009 | Motorola Talkabout T5720 (7 Channels)...
Garmin 530 Radio problem
Did this start happening after the latest download? If so re load the current version of the software and do not turn off the radio until the download is complete.
aburkett61@comcast.net Please answer back and let me know.
Nov 25, 2007 | GPS
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Feb 08, 2007 | Motorola Talkabout T5720 (7 Channels)...
Motorola Spirit HP 2-Way Radio Logo
129 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
