Question about Canon CanoScan D2400UF Flatbed Scanner
I have a used CanoScan D2400U. What is the correct plug pack required for this scanner? The input power for the plug pack will be 240v ac. I would like to know the output specifications of the adaptor.
SOURCE: CanoScan Lide 25 scanner
Come on guys, havn't you herd of this amazing thing called "google", you use it to find things :)
any way go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=119&modelid=11463#DownloadDetailAct
or www.usa.canon.com and search up your scanner model and then click on driver tap, then OS then you can download the driver and free software from there.
Posted on Aug 30, 2008
installer the drivers
Posted on Sep 25, 2008
Install CanoScan Lide 25 scanner via internet; lost CD installer
just want to know how can i install my scanner, i lost my cd i can't use my scanner since i bought this last july 2008. please help me to find the site to download the program of installing my scannerInstall CanoScan Lide 25 scanner via internet;
Thanks very much
Nono Setijono
Posted on Nov 08, 2008
  • 461 Answers
SOURCE: CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
Posted on Jan 10, 2009
technical114
  • 1851 Answers
SOURCE: I've an old Canon Canoscan
There are no available drivers for windows 7 operating system for your scanner. You can download the official windows xp drivers from this link and before run the downloaded file right click on the file and at the compatibility section check the windows xp sp3 compatibility option and hit apply - ok. After this run the file as usual. This procedure will install the drivers is windows xp sp3 compatibility mode.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 02, 2011
I have lost my AC Adapter (HDAD15W101-124) to operate my Medion life USB 2.0 colour flatbed scanner. Can I use a different adapter?
There are a few items that are important when trying to substitute an adapter. Obviously the connector must fit. After that, it is not so much the input voltage/current that is important, but rather the output/voltage/current as well as polarity. The output voltage of the adapter must match the device's requirements. The output current of the adapter must be at least as much as the device requires. Lastly, and most important, the polarity of the connector MUST MATCH, otherwise smoke and flames will occur. On round connectors, most devices have the positive terminal in the center (but mot all).
Aug 02, 2014 | Office Equipment & Supplies
What voltage should be read on each pin of the power adapter?
hello ,, this information is based on ScanJet 5400C - (C8517V) -- if yours is other p/n, let me know
North American use , C8517-84200, Low power AC power module (Wall Mount Type) - 100-120VAC, 60Hz - Detachable power cord not needed (USA, Canada) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
European use , C8517-84201, Low power AC power module (Wall Mount Type) - 200-240VAC - Detachable power cord not needed (Europe) - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
Worldwide use , C8517-84201, Low power AC power module (Brick Type) - 100-240V input - Requires a 3-wire detachable power cord - For worldwide operation - NOTE: Use a High Power AC Power Module if an Automatic Document Feeder (ADF) is attached
i hope thsi helps -- if it does, please rate my service
Nov 13, 2010 | HP Scanjet 5400c Flatbed Scanner
I want to find the part # for canon 3000f AC adapter.
http://cgi.ebay.com/AC-Power-Adapter-Canon-CanoScan-3200F-Scanner-12V-/300416673485?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item45f23aa6cd
this is for the 3200F ..but in the same range cause I know for sure that on your model is a 12 V adapter ...take a look and if the plug is the same ...you can take it without care cause it will work ...
Apr 26, 2010 | Canon CanoScan 3000F Flatbed Scanner
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
What power supply is needed for hp scanjet 2400
It is depends on your scanner power adapter and where u purchase the scanner from. Here if your scanner is from US then the adapter power input should be 100-120V 60Hz AC, if your scanner is from Euro, UK or Australia, the it should be 200-240V 50Hz AC, while if your scanner is from others place that not listed above then it should be 100-240V 50-60Hz AC.
But the best way is look at your adapter itself, u'll notice the power input and output from the adapter sticker.
If you lost your adapter then be sure to purchase 1 that can output a 12 VDC, 340mA, 4.22W adapter to the scanner.
YBC (/\)
Oct 20, 2009 | HP ScanJet 2400 Flatbed Scanner
What ac adaptor does the canon 5000F require (New Zealand)?
Specification:
Input :100-240VAC (50-60Hz)
Output : 12Vdc 1.25~1.5A
those are the specs on it.... any adaptor with 12 volts dc. output of at least 1.25 amps will work you can find them at most electronic supply stores... walmart probably even sells them
Mar 16, 2009 | Canon CanoScan 5000F Flatbed Scanner
I have a canon D2400U scanner. When trying to scan a photo, the scanner does its little back/forward shuffle then slowly drives back, past the start position until it jams and the belt jumps on the gear. ...
I just had exactly the same pb; could find that the 12V dc power unit was bad; changed it and then everything is OK
It looks like the quality of 12V current isn't good (regulation failed)
For replacement I actually used a PC Power unit, and reused the DC cable (with the ferrites) for the scanner's plug isn't a standard one.
May 04, 2008 | Canon Office Equipment & Supplies
Unwanted cropping of some 35mm slides using CanoScan 8400F
Turn off the thumbnails view and you can manually set the cropping box.
Nov 29, 2007 | Canon CanoScan 8400F Film Scanner
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Power problem?
Ensure it is plugged in all the way. Do you have a meter to measure the voltage out of the Powersupply? it should be 12VDC. I would expect some sign of life even w/o the USB connected..
Not a mac person so this may/may not be relevant from the user guide
• iMacs running Mac OS 8.5 or 8.5.1 require a system update.
Please see Problems with the Scanner in the Troubleshooting
section of the CanoScan Setup Utility CD-ROM.
Nov 18, 2006 | Canon CanoScan D660U Flatbed Scanner
Canon CanoScan D2400UF Flatbed Scanner Logo
115 people viewed this question
old marine
old marine
