Question about Samsung Digimax D53 Digital Camera
Locked Memory card
My eight year old was playing with my camera and somehow locked the memory card! How do I unlock it?
    Scholar:
  • 97 Answers
If it's an SD card, there is a little switch on the side of the memory card. Hope this helps!
Posted on Nov 09, 2007
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Camera is somehow "card locked"
The SD memory card should be located where the rechargeable battery is, remove battery cover, should be a small tab holding the memory card in place, move it so the card pops up, remove it and look along the one edge for a switch, slide it towards the contacts to unlock the card. The switch that is furthest from the contacts is in the locked position. Now if you find the card is in the unlock position, slide it back and forth to reset, failing that replace the memory card. Sometimes the slider switch becomes defective locking out the card.
Aug 15, 2011 | Cameras
Ive used my card in my video camera and my digital camera and somehow it got locked.. how do i unlock my card?
Check if you have the tiny lock on either left or right side panel of the SD card. Check if it is slid to lock state.
Good luck.
Jun 19, 2011 | SanDisk 2GB microSD Memory Card
How do you unlock the card on a Canon Powershot A1100is? My wife was playing with her camera and she locked herself out of her SanDisc Ultra II SD Card
Pull the sd card out and look on the left side with the card facing you. You will see a slide switch on the left side. It is probably in the down position (locked). Move the switch up and the card will be unlocked. Done!
Sep 06, 2010 | Canon Cameras
Memory card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 18, 2009 | Canon PowerShot A460 Digital Camera
Camera no longer working
Your memory card must have had the switch moved from locked to unlocked. To fix this, removed the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says locked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on. Try it and let me know if I can help more.
Feb 17, 2009 | Kodak EasyShare C330 Digital Camera
Cannot unlock memory card for my Canon Powershot S5IS
OK take out the memory card and on the side of the card is a small switch...slide the switch to the unlock posistion and that should fix ya
!Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Canon PowerShot S5 IS Digital Camera
Card locked!
Take the memory card out and you will see a little notch on the side. You should be able to push that up or down to lock or unlock it
regards!
VJ
Nov 30, 2007 | Canon PowerShot A430 Digital Camera
Samsung Digimax D53 Digital Camera Logo
42 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
