Question about Hayward SAND FILTER, PRO SERIES
Priming a hayward super pump
I bought a house with an existing pool that hasn't been used for years. I have a Hayward superpump 3/4hp and high rate sand filter. The pump will run water through the waste drain when you fill the plastic pump well with water and keep it coming (using a 5 gallon bucket). You can take a shop vac and easily **** water from the inlet at the swimmin pool at the inlet of the plastic pump well. I can't get the pump to Prime . The only way it will pump water is if I am continually pouring it in. Please help
  • Galan Hardy Jul 02, 2009
    Thanks for the suggestion. I found out my problem was the gasket at the pump inlet well. Once I changed it out it worked, but I had to run the waste option for a few minutes, then backwash, then everything worked ok. I really appreciate the help
  • 93 Answers
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Posted on Jul 01, 2009
Overheating hayward super pump
Superpumps have been a workhorse in the industry for decades. Your results are highly unusual. The motors that run these pumps have bee manufactured by Century/Magnetek and A.O. Smith for the past 20+ years. These same motors power the vast majority of pumps built by a wide range of pool pump manufacturers. (They are not Hayward specific)
You may want to get a second opinion from another electrician, or call out a pool pro to check out the installation to see what could be causing these frequent failures. This is WAY abnormal.
Jul 03, 2013 | Pool & Spa
New hayward super pump trips 20 amp breaker after a few seconds
Use an ammeter that clamps around the wire to see how many amps it pulls. It sounds like a weak breaker.
Apr 01, 2013 | Hayward SUPERPUMP 2.0 HP, 115/230V
My Hayward superpump has a crack in the pump filter basket housing. I cannot afford to replace my pump at this time. Is there a patch or epoxy that will seal the crack? Hopeful!!
I would recommend a product called "Pool Putty". We use it all the time for quick repairs at my pool company. It is a 2-part epoxy that hardens like concrete. It might get you through the rest of the season.
Jun 15, 2011 | Hayward EC-40 DE Pool Filter with pump
How do i take apart a hayward superpump 115/230V serial number c48l2n134b1?
i have a hayward 3/4 hp model c48l2n134b1 motor when i turn it on runs fine heats up and shuts off smells like somthing is burning
May 22, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
May 14, 2010 | Hayward Pool Products Hayward Super II...
My hayward superpump for the pool in leaking
normally this is not a crack in the housing. It is usually a shaft seal.
David
May 14, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Lossing Prime
It's pulling in air very slowly from somewhere:
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
check gaskets/o-rings-- replace defective ones, lubricate
tighten everything possible
Apr 10, 2009 | Hayward 1HP Super Pump II Inground Pool...
Pumps Capacity?
# Aboveground filter systems and small inground pools (under 10,000 gals) should use a Low Head pump like a Maxim, or Dynamo or Power-Flo. # Pools from 10,000-20,000 gals can use a Medium Head pump like a SuperPump, a Pinnacle or Cygnet. # Pools over 20,000 gals could possibly use the High Head pumps like, Super II, Challenger, Ultra-Flo or the Sta-Rite pumps. # Pool/ Spa combos with at least 3 lines influent and 2 - 3 back to the pool, 2" plumbing may be able to handle the Ultra High Head pumps like NorthStar and the WhisperFlo
Aug 27, 2008 | Hayward 2 Hp Max-Flo Swimming Pool Pump...
Hayward SAND FILTER, PRO SERIES Logo
298 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
