ACER T180 KEEPS REBOOTING IN ERECOVERY MANAGEMENT MODE, EVEN WHEN I EXIT AND DO A REBOOT IT STILL GOES TO THE RECOVERY PAGE. USING F8 DOES NOT WORK AS WELL TO ENTER SAFE MODE.
    Scholar:
  • 38 Answers
If it's still under warranty, I suggest talking to your supplier or ringing Acer. If not, by the sounds of it you might be infected by some virus.. or a hardware fault. I am unable to tell. Perhaps getting advice from a local computer shop would be the best way, maybe allowing them to look in to it for an hour and seeing whether it's worth repairing.
Posted on Jun 30, 2009
How to tacke my aspire 5250 back to factory settings
*******All of your data WILL be lost during this process so back everything up first**********
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
OR
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
OR
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Jul 04, 2014 | Dell Latitude D400 Notebook
Aspire one d257-13473 wont factory reset
Windows key > All programs >Acer Empowering Technology>eRecovery management>Restore>Factory(Top of list)..
Or
If computer will not boot.
Tune computer ON
When Acer splash is on screen hold Alt and keep pressing F10...
Select factory from top of list.
You will need a password , the default is "000000" (Six zeros).
Recommend you use the first option if you can...
***This will erase all your unsaved data!***
Or
Or
2. Select Repair.
Dec 06, 2013 | Acer Aspire One D257-13473 Netbook
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
Why is my laptop is stuck in start up mode
Hi bungee221,
You can try to boot the system using Safe Mode and try to see it it will be able to boot so that you will be able to backup your file. In addition to that you disable other programs that might be causing the system not to boot up. Go to Safe Mode by reseting the computer then tapping F8. If your able to acces safe mode follow these instructions:
1. Go to Start then click on RUN.
2. Type MSCONFIG.
3. Go to Services Tab, click Hide Microsoft Services then click Disable All.
4. Reboot the computer and see it it will go to normal mode. It you will be able to boot to normal mode it only means that one of the installed software is preventing windows to load.
5. if still cant boot you neet to reformat the system. Take note that if you reformat the system all the files will be deleted so its better to back up the files first. You can use a Recovery Disk that came with the system or you do a Acer Disk Recovery.
Acer Dsik Recovery Steps:
1. Power on the Machine
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit.
If you think this helpful rate me and dont forget to say thanks. Thanks for using Fixya.
Feb 05, 2011 | Acer Aspire 5920-6335 Laptop
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a Acer Aspire 5745 (CPU: Intel i5 processor 2.5GHz RAM: 2GB OS: Win 7 Home Basic) which is only 2 months old. Yesterday I started a installation setup of a game, when suddenly the system restarted....
Hi, I do apologize for the inconvenience you have been facing.The reason why the laptop does not reboot to Windows even after reinstalling Windows is because the issue is with the hard drive not being recognized the reason for which you get a blinking line on the screen after the Acer logo .In this case I would suggest that if the laptop is under warranty please contact the Acer Technical support and have an order placed for repair.
Thank you for your time and best wishes for your effort.
Nov 19, 2010 | Acer Computers & Internet
Acer aspire 5515 erecovery manager does not work. i can see three options restore from factory or user disc or exit the only one i can choose is exit
try restarting your machine. tap the correct key to get into your bios. most of the time its f2. in there make sure the recovery mode is active/enabled. i believe on an acer its called D2D. then when you restart your machine hold down shift key and tap f8, that should take you through the recovery. let me know if that helps
Good Luck!
Ruben
Jul 15, 2009 | Acer Aspire 5315 Notebook
Acer t180 boots to erecovery
Borrow any Vista install DVD and boot from it
Follow it through until you are asked if you want to install Vista or Repair your Computer
Select repair and let it do its thing - it may work
Failing that its a full reinstall by the sounds of it
If it does not offer you the initial boot option then look on the boot screen for the boot options key - probably F11 or F12 - and press that during initial boot to obtain the boot options screen
Dec 19, 2008 | Acer Aspire™ T180 PC Desktop
Could not reboot computer from cd using manufacture recovery disc
boot into safe mode (F8 on boot) and perform a system restore
kind regards
Dec 09, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
