I have a Rheem RT-36-ACU-N that acts like it needs a blower motor. Also I am replacing the AC unit this fall with one that has a higher SEER number. Can the motor be replaced with one that will have a higher CFM?
    Sergeant:
  • 340 Answers
Yes, but why more cfm? you need the proper cfm to match the tonage higher cfm wont accommodate your present blower wheel .have a load calculation done. A reputable contractors will do it for free as long as ya buy from them you will be happier with a prorerly sized unit. Good Luck Tom
Posted on Jun 30, 2009
Purchased Rheem 4 ton 16 seer AC installer just left
Ask your installing company for the AHRI number. If installed with a
matching furnace and coil as listed in the certification then you will get 16 seer rating. If they installed something different than what is listed in the certificate then demand all parts listed or a refund.
Jul 18, 2014 | Rheem 14AJM49A01-RHLLHM4821JA 4 Ton 16...
13 seer 2 ton reheem ucentral air very noisey what is a more quiet make
Unfortunately the quieter ones are more expensive. I have a variable speed Trane '19 seer' which is extremely quiet. But, with the higher 'seer' I save money on electric.
Jul 10, 2014 | Rheem 13AJN24A01 2.0 Ton 13 SEER Air...
How do you clean the fan in a rheem air handler?
Pull the blower assembly...2 screws on the angle bracket holding the blower & disconnect the wiring if needed to the motor.
May 28, 2014 | Rheem Complete Split System Straight...
Aircondition builds ice on coil
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil) Good luck.
May 19, 2014 | Rheem Complete Split System Gas Furnace 5...
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
Do you know where i can buy or get a gas blower tube for my ''Ruud Achiever Self-Contained 10 SEER Package Gas/Electric Unit''
Rheem and Ruud are the same equipment, so look on line for a supplier of either brand, they just have the first number of the model number that is different.
What do you mean, when you say, gas blower tube?
heat exchanger, inducer draft motor?
Give me a shout back and let me know.
Sincerely,
Paul Gibson
Apr 06, 2010 | Heating & Cooling
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
515 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
