Question about HP Pavilion MX70 17" CRT Monitor
My color monitor (hp pavilion mx70) is having graphics problems
Im using xp pro sp2. my graphic options are only
4 bit (16 collor) and 640 x 480.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Sounds like your missing the video drivers from your graphics card in your computer. What video card do you have in your computer?
    New Friend:
  • 76 Answers
Need to download correct graphics drivers and then you will be able to change the options. If you already have up to date drivers then you need to Right Click on desktop and select properties and then click on the Settings Tab and change it from 16 color to Highest (32 bit). Oh, go to manufacturers web site to download drivers.
Posted on Jul 05, 2009
Monitor result change 16 colors
One of your applications are changing your color scheme to 16-bit because it isn't compatible with your OS or graphics card. Try reinstalling your drivers, then disabling programs one by one when the problem occurs. For example, games that used to run on windows XP or older tended to change the color scheme and resize the monitor to 480p.
May 19, 2014 | Nvidia Computers & Internet
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
I need to know the monitor resolution & refresh rate on my HP Pavilion Pentium lll 8756C computer.
Video Attribute Properties Video graphics PCI local bus Controller Intel 810E (on motherboard) Video memory 11 MB shared memory, integrated graphics, not upgradable Feature connector (game/joystick) Yes Resolutions: 640 x 480: 16/256/32K/64K/16.7M colors
800 x 600: 16/256/32K/64K colors
1024 x 768: 16/256/32K/64K colors
1280 x 1024: 256 colors s.gif
Feb 17, 2010 | Computers & Internet
HP Pavilion dv7 goes into sleep while im gaming what could the problem be? overheating?
Hi, Click on start, controlpanel, power options, advanced and check your settings there. But depending what support you have inside the computer gaming could be too much.
Feb 06, 2010 | HP Pavilion MX70 17" CRT Monitor
Wddd COMPATIBLE drivers
You will not have the Transparency option if you have a Basic and High Contrast Theme instead of a Aero Theme.
Aero Requirements to be Enabled in Windows 7:
NOTE: If Aero is not enabled, then Transparency will not work even when enabled.
Feb 05, 2010 | HP Pavilion dv2000t Notebook
I can only get 480 x 640 resolution and 4 bit colors and all the graphics are fuzzy
It appears the graphics card driver has not been installed. Check the device Manager and if you get a yellow ? against the Display Adapter then you need to install the graphic driver.
If your computer is a Compaq or HP then you need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model computer and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
If your computer is not a Compaq or HP desktop computer and you know the make and model of the graphics card in your computer then go to the graphics manufacturer's WEB site to download the graphics driver.
Sep 30, 2009 | HP Pavilion M90 Monitor
HP Pavilion a1610n will not boot up. I get the blue HP logo screen, then the monitor either goes to solid blue or has the HP logo in broken patches across the display. Computer is not recognizing mouse or...
If you have tried another monitor and result is the same, then it's a faulty graphics card.
If graphics card is sharing system memory, then you might need to replace ram to get it work again.
Jul 30, 2009 | HP Pavilion a1610n PC Desktop
Hp 510 notebook -graphics - low resolution
I suggest uninstalling SP3... do you have System Restore turned on? Google how to check...
If you do, try rolling back that way. Start>Run>restore <enter> and the restore window will appear. Choose the restore to an earlier time option, and hopefully a choice for 'SP3 installation' will be there. Choose that to roll back... good luck!
Apr 06, 2009 | HP 510 Notebook
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor won't work with new computer
The computer in question has two graphics cards in it. A GEForce 8400GS Graphics card and an onboard graphics card. It could be possible you are plugging the monitor cable into the wrong graphics card slot. The onboard graphics card slot may be a different color than the GEForce graphics card slot. Check the back of the computer to see if there is another spot to plug in the monitor.
Jul 13, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion MX70 17" CRT Monitor Logo
380 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
