Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I'm trying to remove the handles from my GE refrigerator
    Novelist:
  • 103 Answers
Some handles have plastic inserts or caps which snap on to the main handle from outside to hide the screws...you can carefully pry open those caps with a knife or screwdriver to reveal the screws....some are only accessible by first removing the inside panel to reveal the screws from inside the door.....in either case the panels are usually just helld in place by snapping together or in channels or rails.....they can be pryed off but with care to avoid cracking them or breaking them because you need to re-use them when you put back the handles.
Posted on Jun 30, 2009
How do I remove door handles from GE a side by side refrigerator?
If it is a newer model you can look for set screws on the inside of the handles. Use a small allen wrench to loosen the set screws and lift up on the handles.
Apr 19, 2018 | GE Refrigerators
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
Dec 20, 2015 | Refrigerators
How do I remove ge GBS20KBPACC handle for reverse door swing
You just grab the handle with both hands and pull/lift up like your trying to lift the fridge wirh the handle. It should disengage and then pull off.
Mar 30, 2012 | GE Refrigerators
Removal of handles on GE side by side
Remove the insert that is on the handle and you will see the screws that need to be removed for the handle to be removed.
Dec 20, 2011 | GE GSH22JFR Side by Side Refrigerator
I have a GE Side-By-Side Refrigerator Model # TFX20JR . The refrigerator handle is loose and needs tightened and I can't find anything in my manual telling me how to do it. Your help would be greatly...
you must remove the inner panel to get to the handle screws on most ge 's . use red lock tight on threads to prevent it from doing it again . mm
Aug 09, 2010 | GE Refrigerators
Door handles have turned yellow and i can not get
Try straight chlorine bleach with gloves on that is. If this doesn't remove the yellow stain you can forget it. You will have to replace them instead.
Dec 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
One handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Refrigerator model #TXP24PRYE with yellowed handles
Spray with clorox all purpose cleaner and scrub it with hot or warm damp wash cloth.If the handles are plastic, Krylon makes an excellent line of spray paint products that bonds to plastic and adheres to the surface. Most spray paint products only coat the plastic and on a surface like a handle that will be used constantly, is easily scratched or peeled. The Krylon plastic paint bonds to the plastic surface and is very durable. The one down side is if you paint the handles and don't like the results, there is no going backwards, you can't remove the paint once it has cured.
Thanks.
Jun 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Cannot get handle off GE side-by-side GSF25TGTA WW to tighten screws underneath
the handles have two caps one on the top and one at the bottom , just remove them with a small screw driver and you see the screws
Jun 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loose handles - GE monogram model # ZFSB25DMD SS
try removing the handle, that will expose the mounts for the handle. You should be able to tighten them after removing the handle.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
