Question about E-Machines eMachines Desktop PC
My dell dimension 9200 desktop won't boot up. When I turn on the machine it remains in standby mode, ie. the power light is solid amber. I all the fans and drives power up but the computer will not even post the BIOS. Any suggestions? Thanks.
I work in my own computer repair shop, I've worked on a few Dells, to say the least.
A bad power supply will provide you with the situation you describe as well.
Plug in another Dell PSU if you have one...
Posted on Jun 30, 2009
    President:
  • 948 Answers
Unplug the unit. Open it and reseat all components you can reach and all cables. Blow all dust from the unit. Try to boot again. If still unresponsive, remove all memory and replace one piece at a time. Attempt to boot with each piece, try all the available memory slots. If still unresponsive your motherboard is probably the culprit and the system needs a technician to look at it.
Why am I unable to boot my desktop dell
Several possible reasons, best (if not under warranty) to check RAM memory for faulty one, seems like possible memory of AC issues.
Aug 26, 2014 | Dell Dimension 9200 PC Desktop
Dell Dimension 9200 does not boot.
remove ram and listen beep codes from the system ......still no beeps from the system .....the problem with motherboard only
Oct 15, 2012 | Dell Dimension 9200 PC Desktop
Dell desktop 4700 problem
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
If the LED Is SOLID amber, it is likely either a component connected to the Motherboard or a bad motherboard
May 15, 2010 | Dell Dimension 4700 PC Desktop
Dell 4700 desktop, will not boot up. Light remains
A solid Amber power LED is an indication of a motherboard problem. Remove any external connections and see if LED indications change. If no change, remove all PCI expansion cards, try again. If still no go, disconnect all drives, try again. If still no change, ensure the CPU heatsink is firmly attached (If loose you need to replace the retention module) If nothing loose and no changes from other steps, replace motherboard
Mar 11, 2010 | Dell Dimension 4600C PC Desktop
I have a Dell Dimension 9200. Having a problem with power to PC. The power supply unit is working fine. The power switch seems to be ok, but the machine will not power up. Do you have any suggestions
Please check on the power button if the Led is steady amber it requires motherboard replacement. If the light is steady green check the cables in the system that they are connected properly.
Jul 11, 2009 | Dell Dimension 9200 PC Desktop
SOLID AMBER LIGHT ON DIMENSION 3000
One of two things:
Either the power supply is marginal
or
the motherboard is bad.
Good luck.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Computer turns on but now booting up
Make sure the memory stick is securely installed on the motherboard. Also make sure that any additional cards in the expansion slots are also securely installed.
I had a similar problem on another machine and it was due to a memory stick that wasn''t fully secure, I reinstalled the memory stick and made sure it was a solid connection and it resolved my problem.
Please let me know if this helps you.
Feb 03, 2009 | Dell Dimension 3100 PC Desktop
E-Machines eMachines Desktop PC Logo
219 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
