Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
Garmin GPSMAP 295 GPS Receiver Logo
Problem with the Garmin GPSMAP 295 GPS Receiver
Garmin gpsmap 295 will not run from internal battery power
By rob4day on Jun 30, 2009
My garmin will not run from internal power but runs good in cigarette lighter power. Any Ideas??
Best Solution (1 of 7)
posted 3 months ago
  • Rank: Master
  • Rating: 100%, 2 Votes
I love you people! This must be a common problem. I had all sorts of intermittent problems when running on batteries alone - including the message: "external power lost, shutting down....." , this was when no external power was connected at all. For me it turned out to be the same loose screw, there was even a small gap under the head.
Was this helpful?
Yes
No
1 person thought this was helpful
Add a comment
Solution 2
posted 10 months ago
  • Rank: Apprentice
  • Rating: 100%, 1 Votes
I had the same problem. After following the instructions in solution number two the problem was solved and my 295 is working flawlessly.
Was this helpful?
Yes
No
Add a comment
Solution 3
posted 12 months ago
  • Rank: Apprentice
  • Rating: 100%, 4 Votes
I followed the instructions in solution number two, which were concise and helpful. Though there was not a screw missing of the three, the battery screw was loose. I tightened it up, and voila! the internal battery now works perfectly!. I am going to use the cigarette connector (an AD has caused the cigarette lighter wiring to be disconnected in my C-182) to the 295 and construct a battery pack as described by another suggestor so as to give me more time between battery changes,
Was this helpful?
Yes
No
4 people thought this was helpful
Add a comment
Solution 4
posted 1 year ago
  • Rank: Guide
  • Rating: 96%, 7 Votes
I'm going to second DavidS0150's solution - I just took mine apart (it would turn off when i pressed down on one side too hard, plugging the cable in and out, etc.) and found a loose screw holding the circuit board down (far left, circuit board closest to the battery). A good tighten, plus checking the rest of them, put it back together, so far good as new! Thanks David - I've spent a couple months looking for an answer to this!
Was this helpful?
Yes
No
5 people thought this was helpful
Add a comment
Solution 5
posted 1 year ago
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I had the same problem. Reluctantly, I removed the batteries and the 8 phillips screws from the the case back perimeter. Be careful on opening. The unit is designed to open from the top and hinge at he bottom to keep the ribbon cables from being stressed. The unit should open nicely and lie flat on the table with the two bottom halves butted against each other. Get a magnifier and ensure the printed circuit board attached to the bottom half has all 3 screws. (I found one missing that has 2 functions - securing the board and delivering battery power. Mine had wedged against a piece of clear plastic...it was hard to find!!!) I carefully removed the wedged screw and returned to the circuit board left most attach point. Close up the unit and we were back in GPS heaven. Battery power restored!!!! and my $250.00 still in my pocket. Yipppeee.
Was this helpful?
Yes
No
11 people thought this was helpful
Add a comment
Solution 6
posted 1 year ago
  • Rank: Wiz GPS & Car Electronics
  • Rating: 85%, 2769 Votes
change the battery
Was this helpful?
Yes
No
2 people thought this was helpful
Add a comment
Solution 7
posted 19 days ago
  • Rank: Apprentice
  • Rating: 0%, 0 Votes
Had the Same Problem with the loss of battrey power, followed the advice above. (Loose Screw) Sorted.
Many Thanks.
Was this helpful?
Yes
No
Add a comment
Solve Your Garmin GPSMAP 295 GPS Receiver Problem Now!
Click here to get instant support from our best Experts
Please type the numbers below to complete your post:
Can't read it? Try a different one.
Type the numbers here:
Solve this problem
Bold
Italic
Underline
Insert List
Insert List
Video
Pictures
Insert Link
Links
Share your knowledge with the Fixya community today!
Popular Solutions for Garmin GPSMAP 295 GPS Receiver
I am trying to update my garmin 255w and not
I am trying to update my garmin 255w and not getting anywhere. I have no idea what I am doing wrong. Help
how to download a map update
how to update my garmine
how to update my garmine nuvi
touch screen not working
My Garmin 255W thinks it is in Kansas and is all
My Garmin 255W thinks it is in Kansas and is all fouled up. When I put my home address in it has 1045 miles on it. It ...
Unsolved Problems rss
I have a garmin 295, was working fine. I have not
I have a garmin 295, was working fine. I have not used the unit for two months I went to use the unit and it will not ...
Need replacement yoke mount for garmin 295 for
Need replacement yoke mount for garmin 295 for airpalne
I have a 295 yoke mounted gps for several years.
I have a 295 yoke mounted gps for several years. The other day I took one flight and landed, on second flight 295 beeped ...
NO BATTERY POWER,ONLY EXTERNAL SOURCE
Garmin 295 no battery power only external source will power up the unit
Vertical lines in the display very hard to read.
Does not go away with time or different pages ( screens) Any Ideas? Does anyone service them or are they not worth the ...
Solve this problem:
Bold
Italic
Underline
Video
Pictures
Insert Link
Links
What is this?
Get an Expert to Solve your Problem:
Top GPS Device Experts
Rank: Guru
Rating: 91%, 6509 solutions
Rank: Guru
Rating: 86%, 5338 solutions
Rank: Guru
Rating: 89%, 277 solutions
Get an Expert to Solve your Garmin GPSMAP 295 GPS Receiver Problem
Get Immediate Assistance!
Let our Experts solve your problem!
More than 2 million solutions and counting...
