Question about Canon PIXMA MP600 all-In-One InkJet Printer
I am getting a Code 5100 error during the intial setup (right out of the box). I have installed and re-installed the ink cartridges and the Print Head. What am I missing?
    New Friend:
  • 12 Answers
Craig's advice is excellent. Worked for me! Used some alcohol with the Q-Tip as the problem was ink that had splashed from the collection pot during shipping.
Posted on Jun 13, 2013
    President:
  • 2,306 Answers
5100 error means the carriage is not moving right and left properly, or there is grease on the encoder strip. Look at the clear strip with black stripes behind the carriage and wipe off any grease with a Q-tip.
Posted on Jun 30, 2009
I just purchased a Canon Pixma MG6220 and during setup ~> (right after I installed ink cartridges) I received an error code 6C10 ~> telling me to power off printer and restart ~> when it restarts...
I Tried everything,then I had the print head in the middle and turned the printer upside down and shook,out fell a little piece of foam from one of the ink cartridge,now works great.
Oct 12, 2012 | Office Equipment & Supplies
A friend has a Canon MP630 inkjet which seems to have seized up after a paper jam earlier. He's getting an error code of 5100. If anyone knows what that means it would be much appreciated. Thank...
Hello and Welcome to FixYa!
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error
. To solve it:
First of all turn off printer
then remove both the cartridges from the printer.Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches. After it return the cartridges and turn on the printer.Error will be automatically remove
I hope this solution helps you
Thank you and Keep using FixYa!
Jul 20, 2011 | Canon MP830 All-In-One Printer
Hi, when I power up my MP630, there is a loud clacking sound and then I get an error code of 5100 of 5C20. There is no paper jamed - can you help?
Error Code 5100
It can have a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. The purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on)
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can't remember exactly what it said but it was something like that).
8. Open printer, lift the gray arm that surrounds the ink cartridge area and reinsert the ink cartridge holder (with the ink cartridges in it). Lower the gray arm.
9. Close printer cover.
10. The display should appear normal now, and you should be able to print again.
Jul 09, 2011 | Office Equipment & Supplies
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
I'm getting a 5100 "check printer" error on my
Reseat (remove / reinstall) the ink cartridges if an error appears. Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I just installed the printer head and ink cartridge and now there is a 5100 error code. Cartridge is extreme right. I can't get anything else to happen.
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Nov 29, 2009 | Canon SELPHY DS810 InkJet Photo Printer
I have a canon Pixma MP620 photo All-in-One Printer. I installed the print head and ink tanks gently and without problems. Lights lit up on all tanks. I closed the scanning unit and the LCD displayed the...
I found a solution if you get an error code. I just bought a canon mp620 tonight from Best buy. I followed it to the letter as far as putting the ink in. Closed the lid and it made some God awful noise. The code was C000. You need to COMPLETELY push the ink tanks down underneath their respected sticker letters. Goto www.usa.canon.com look under support. Type in your model number and look under FAQ'S. I also had the error 5100 code. It explains with pictures and instructions what to do. Hope it helps anyone with trouble with the error code c000 and 5100
Nov 16, 2008 | Office Equipment & Supplies
5100 error code
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Service error 5100 on canon pixma mp130
When this happened to me, I beat my head against the wall until I finally figured out that the waste ink absorber on the right side (spongy looking thing), was overflowing, and clogging the nozzles. I took a piece of paper towel and absorbed some of the ink. Make sure to wipe the colored ink absorber as well.
Neal Moilanen
AAA Virtual Assistants
http://www.aaava.net
Jan 24, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
131 people viewed this question
old marine
old marine
