Question about Dometic Rooftop RV Air Conditioner
I have a Dometic roof mount A/C unit, this morning I noticed that the compressor is not shutting off and the only way to shut off the compressor is with the main breaker.
  • 378 Answers
Check the thermostat switch it might be stuck. or over setting.
Posted on Jun 30, 2009
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
Dometic roof ac will not cycle
check wiring and dip switches make sure fan on auto
Jun 14, 2012 | Dometic Rooftop RV Air Conditioner
Want to check for leaks and recharge a dometic rv roof unit 2007 compressior kicks in and out and not cold
They are a sealed unit, and you would have to get a Refrigeration tech to install valves to do so, which usually costs close to replacing upper unit (roof unit).
A few things come to mind in your case.
- Are you getting proper 120 AC Voltage?
- Has unit been cleaned recently, as in filter, evaporator, condenser ? Any of these plugged can cause it to shut down.
- is it freezing up due to improper flow from discharge ducts, as in have you closed too many ? Remove filter at ceiling and have a look at coils/fins, at front for frost forming on them when it shuts down.
- How long does it run before compressor kicks out, and how long before it comes back on?
- Does it feel cool when compressor kicks in?
Get back to me with more info if you can, so we can narrow it down better.
Feb 14, 2011 | Dometic Rooftop RV Air Conditioner
A/c unit vibrates entire rv. could not find any
You may have to remove cover on roof and check condenser fan as well. That will also allow you to observe for possible fan wobble, bad compressor mounts etc. Please shut power off at breaker until you have cover completely off, and be real careful for wasps, and roof may be slippery if wet, or early morning dew on it. Stand back, hands back and have someone turn it on.
Jun 15, 2010 | Dometic Rooftop RV Air Conditioner
AC ROOF TOP CYCLING EVERY 5 MINS
well most unite will go to 54 degrees but 43 that coooool man what complain about. the compressor dose shut down at certain temp so as not to turn into one hunk of ice. that what they are design to do.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
158 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
