Although more info would be helpful, the first thing that comes to mind
is that, somehow, the power to to ignition system was disconnected
when the starter was installed. Easy to check... take off a spark plug
wire at the spark plug, put a small piece of wire in the end, and place
this 1/4 inch away from engine block... be sure there is no gasoline or
gas fumes near. Have someone crank the engine and look for spark
from the plug wire to the block. If no spark, may well be the ignition
system (do this in shaded area so you can see the spark). If you have
spark, then the problem is elsewhere.
SOURCE: i have a mitsubishi pajero it wont start when turn
Yes, check starter connections... Power is getting to the relay.
