Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
No video I took out my 80gig ide hard drive and took off the jumper to my 320gig hard drive to switch it from 1.5gig a sec to 3gig a sec turned my computer back on and no video everything else seemed to be working but no video. so tried putting everything back the way that it was but still nothing tried clearing c-mos but still the same problem what can I do to get my computer back up and running?
  • 5 more comments
  • Zaner Nov 09, 2007
    Yes it doe's
    Please help me I need my computer back.
    if this also helps
    amd 64 x2 4200+
    2gig mem 667
    dvd rw
    7600gs video nvidia
    xp pro sp2 full install
    adigy sound card
    segate 320 hard drive
    upgraded bio's 0603
    please help me this is a new upgrade for my computer and only been running for about 5 months
  • Zaner Nov 10, 2007
    I did I don't know what I have no because I have no video to see if the bio's even post. I don't know what to do I have never had this problem before.
  • Zaner Nov 11, 2007
    yes it is plugged into the right one. To be onest with you out of desperation I did try the other plug in and the I even took out my sli video card and put in a regular pci video card and that wouldn't work eather.
    the monitor is working. I have it hooked up to my wifes computer right now that is how I am being able to talk to ya.
    No I have not tried the video card in another computer I don't have another computer that will support sli video card. Like I said before I tried a pci video card on my new board and it didn't work either and to answer right now the pci card doe's work.
  • Zaner Nov 12, 2007
    I am not trying to be rood I am just frustrated that my computer won't work I have never had a computer go capute on me before.
    please help me. PLEASE.....
    Genius:
  • 1,601 Answers
Does the 320gig hard drive have an operating system on it?
Posted on Nov 09, 2007
  • 3 more comments
  • Thomas Christopher
    Thomas Christopher Nov 10, 2007
    do you have the right video source as default in the BIOS?
    Did this work?
    Please post an answer so we can help you further.
    If it worked please rate this post as solved.
    Thanks,
    This may sound stupid, but is the monitor hooked up to the right. vga port?
    Thomas Christopher Nov 11, 2007
    is the monitor working?
    did you try it on another PC?
Pins location master slave
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Hope this helps
Nov 24, 2012 | Gateway Motherboard Gt5408 Gt5438 Gm5407e...
How to make a master fujitsu mvh2080ah? Which jumper do I have to use to render the 2.5" hard drive master? Thanks a lot, Mustapha
Fujitsu might be different have a look on top of the hard drive this is if your hard drive is IDE 40 pin flat bibbon type leads
if its a SATA hard drive the larger drive takes the master
slave :::':
hope thie helps
Jul 20, 2012 | Fujitsu Computers & Internet
Select as master
slave :::':
Nov 14, 2011 | Samsung (SP0411N) 40 GB Hard Drive
S.smith1@hotmail.co.uk How do I slave HDT721050SLA360 500GB 7200rpm
if you want to set a master / slave on you computer
slave :::':
Aug 26, 2011 | Hitachi Deskstar 7K1000B HDT721050SLA360...
How do you connect the cables or jumpers?
the leads from your ((motherboard to your hard drive)) they might have a 40 pin on the hard drive or a sata they just push on to make a connection make sure they have a secure connection
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
?don't forget to vote
Feb 08, 2011 | Western Digital Caviar SE WD3200JS...
I need to put my hard drive into an enclosure but I cannot figure out if I need to switch it to a slave before adding it to another computer
i have done this alot for my customers and its really simple. if you look up your drive and get the jumper settings for it and set it to cable select or master in a one drive enclosure it will work well. i do not recommend putting it on slave because some enclosures will not recognize the drive, I do recommend having an enclosure with a fan on board and an external power switch. the reason it the fan will extend the life of the drive and the power switch eill allow you to power it on and off without having to flatten (power hot swap) the drive. Hot swap is ok but this is better than just unplugging the drive. removing the power from the drive keeps the drive in park until you re-power. as long as the drive is "parked" it is les likely to cause read/write sector errors.
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 01, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Is there a slave or master switch on the hard drive want to hook up a external hard drive enclosure
hope this helps
Jan 29, 2011 | Hitachi Deskstar 7K500 500 GB Hard Drive
Need jumper settings for slave drive WD1600JS
slave :::':
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD1600JS...
TAKEN OUT A TOSHIBA 80GIG DEAD DRIVE, lAPTOP
It is an IDE hard drive. Thr IDE drive will have a double row of 44 data pins
Mar 29, 2010 | Toshiba MK8025GAS 80 GB Hard Drive
Is a 80gig western digital hard drive compatableto a asus p2p pentium 2 celeron motherboard if so what are the jumper settings for the hard drive and do i have to change my jumper settings on the mother...
hope u r a professional..
yes, itz compatible..
howevr, for all pata ide drives..remember the master(MA or MS) jumper is always in a vertical position along or just beside the ide cable port/pata port..while the slave is either 'open-all' or just beside..
there's no such jumper to b fixed on the main/mother board..
for details contact system admin/vendor....
Nov 10, 2009 | Western Digital Caviar (wd800lb) 80 GB...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
