Question about Samsung SlimFit TX-S2783 TV
Weird noise over everything
The TV will be fine then all of a sudden it will have a high pitch ting(like i high pitch buzz) over everything that it is on. I have turned the equalizer all the way to each side to see if its the speaker and it does it on both. The weird thing is that it will be fine for a while and start to make the noise. I'll get use to the sound and then it will go away, then come back again? It is a HDTV and I have it hooked up to a standard definition cable box and tivo box. Could that be the problem?
  • serious mojo May 10, 2008
    I have the EXACT same issue!!! Is there a relatively inexpensive fix for this??
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Posted on Feb 07, 2009
The problem is not with the Audio. It is coming from the capacitators on the main PCB. A tech opened up our set and reproduced the noise by slightly moving the capaicators (with a stick of some sort). Instantly, the high-pitch ring started. This problem has since came back on thew new PCB and seems problematic with the type of TV/Samsung.
Posted on Nov 26, 2007
Tv just started making a very high pitched noise, although picture and sound are fine?
Barb, noise may be from a power supply/ transformer on it's way out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HELP what is that high pitched noise when tv is on
Is your LCD making buzzing or high pitch noise
Mar 04, 2016 | Sanyo Dp55441 TV
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ... > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2 > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ... > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from
High pitched sound coming from my Samsung DLP TV - Open Forum ... > Forums > Social > Open Forum
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
High pitch buzzing and no picture
Your power supply, I mean the internal power suppy could be faulty, if you know how to deal with it, check it for abnormal oscillation, or get some help from someone who knows how to repair it.
Jan 28, 2008 | Sansui CVDV9000 9 in. TV/DVD Combo
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
Samsung SlimFit TX-S2783 TV Logo
448 people viewed this question
Jerry Greenberg
Jerry Greenberg
