Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
My hayward 1hp pool pump is running very hot to touch
    Problem Solver:
  • 11 Answers
Common problems for pump overheating: debris in impeller, worn bearings, low supply voltage.
Check those first.
Posted on Aug 11, 2009
  • 27 Answers
Make sure the supply wire is the correct gauge for the current draw. The main reason to run on 240 volts is a smaller gauge wire and breaker than on 110 which draws close to 15 amps. For example a person using an above ground on a small extension will cause it to overheat. Make sure it is getting as much power as possible
Posted on Jul 20, 2009
I have a Hayward Super Pool pump for my inground pool. Was running the pump, heard a noise, by the time I got over to the pump to check it it shut off. It has been off for over 2 hours. It is not hot....
Get another brand. Hayward is junk. I had the same exact thing happen. Of course warranty is only one year. I paid out of pocket to replace the motor. Guess what happened 2 years later?
May 08, 2014 | Hayward Pool Products Hayward Northstar...
I have a Hayward, A.O. Smith sp-1510-z1 xe8k3, 1 hp pump. It is not turning and is getting hot and started to smoke. Is there anything I can try before I replace it?
SEPERATE THE PUMP FROM THE MOTOR AND SEE IF THE PUMP TURNS FREELY IF IT DOES THEN THE MOTOR IS BAD IF IT IS HARD TO TURN THE PUMP PLUG IN MOTOR AND SEE IT IT NOW RUNS IF IT DOES ALL YOU HAVE TO DO IS REPLACE THE PUMP IF THEY SELL IT SPERATE GOOD LUCK
Oct 22, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
Pump runs for about 3min and shuts off
It sounds like it is overheating. There is a thermal switch that shuts the motor off if it gets too hot. This may be because the motor is pulling too many amps due to a bad winding or the bearings are starting to seize. The best solution is to replace the motor.
Jan 11, 2013 | Hayward Pool Products Hayward Northstar...
How can I tell if my noisy Hayward Super 1hp pump noise is in the motor or the pump?
99.9999% OF THE TIME its the bearings going bad, and need t be replaced asap.due to a bad shaft seal... search your area for your local pool pump motor repair guy with free testing. should be around $75 to repair it if caught in time.. here in florida lizards,frogs,grass and snakes and the such get into the motor and you can get that grinding sound but it will soon fade, but can restrict airflow and make your motor run hot and fail prematurely.. so if the noise doesn't fade in say a hour or two.. have it checked .. here is how to remove most pump motors just click on this link.. hope it helps ya .. jay florida
Jun 22, 2010 | Hayward 1HP Super Pump II Inground Pool...
Just purchased a new super pump 1hp, but it is
Can you be more descriptive? My guesses are that the motor is wired wrong, the motor is defective, There is a leak in the supply line or the pump and air is getting into the pump, causing the pump to cavitate.
Jun 02, 2010 | Hayward 1HP Super Pump II Inground Pool...
My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
Jul 03, 2009 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Does the live black wire need to be on the jumper side of the hayward super pump direct wiring ??
It does not matter which side it is on as long as hot is on one side and the neutral the other.
Jul 01, 2009 | Hayward 1HP Super Pump II Inground Pool...
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
863 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
