Will not work on gas or elect. just clicks twice and check light comes on. RM2652
SOURCE: Dometic Model # RM2652
Check with a DC meter on fuses to verify voltage is passing then check at the input on back side of the fridge to verify voltage is there. If yes to both it can be the eye brow or the lower control board hard to tell without further testing.
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
SOURCE: Dometic rm2652 re-ignitor
Dear sir/madam,
Turn the refrigerator off and remove the wire
between the electrode and igniter. Now turn the
refrigerator to the gas mode. If no internal
clicking sound is heard the igniter is defective.
It is important to remove the high voltage wire
that goes to the electrode from the igniter when
you are checking the igniter for operation. The
high voltage wire and the electrode can be
shorted to ground causing the igniter reigniter
to think that the flame is lit, resulting in no
spark on gas operation.
thanks
good luck
SOURCE: Dometic RM2652 or RM2852 not working.
There is a factory recall on these refrigerators. Call Dometic 1800-544-4881 and give them your serial number and model number. Going through the same thing right now. On my Fleetwood Gearbox. Hope that helps. Robert
SOURCE: RM2652 fridge works on 110 and gas but won't switch between them
Remove the upper control board panel. Use a small screw driver, open the freezer door, under the control panel you will see a slot on each side. Put the screw driver in the slot and push up. That side of the panel will pull out. Do the same on the other side. Turn the control panel over and unplug the circuit board and wait 15 seconds. Plug the board back in and give that a try. If that does not work replace the upper board. To order a board you will need Model, Serial and product # found on the inside of the fridge.
Thanks for using Fixya
Jerry
