Question about Danby Dehumidifiers
The fan works but it is not drawing water out of the air and the basement is moist i CAN'T find the manual to find the cause - Should the temperature settings be at a certain number?
I got the same problem before, then I found it out , the humidity on the LED display is not correct, acturally is much more lower than actural reading. so only cold wind blowing out, not the warm wind.
Posted on Jun 30, 2009
My GE basement dehumidifier is overheating. The bucket still collects water and the fan works, but the unit is putting out alot of heat. My dad is visiting and has taken the whole thing apart. Any...
Yes, the first suggestion is I hope your dad can get it back together without any parts left over (LOL). Over heating is generally caused by an clogged or dirty air intake filter. Simply removing it and vacuuming it or if it's really dirty, washing it in warm water and mild dish washing liquid will clean it. Rinse it thoroughly, shake off excess water and allow to dry completely. Never operate the unit without the filter in place. Doing so, can damage the unit.
Getting back to the heat for a moment and where you're using your dehumidifier. Dehumidifiers do generate heat, it's not abnormal. Operating it in a basement can cause it to over heat. This happens because the air temperature at floor level is colder than at shoulder level. Dehumidifiers struggle in temperatures below 65 degrees F (unless you have a Low temp unit, designed for basement applications). Raising the unit up off the floor, on to a sturdy table, counter top, etc, that an handle the weight of the unit, plus a full bucket of water, will generally resolve the problem.
Actually, a basement application , higher is better.
I hope this helped you and thanks for choosing FixYa.
Aug 16, 2011 | GE AHG40LJ Dehumidifier
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
Unit no longer removes water/humidity from air. The filter had been extremly clogged up (now clean) but is fan suppossed to move when it's running ? If so - is it electric or belt driven ? Is...
Well, we know the filter was playing a role in it.. Good job on cleaning that. Depending on where you have the humidity extraction level set, the fan could run all the time (It's direct drive. No belt). I suspect if you lower the humidity extraction level to 35%, you will see/hear water collecting in the bucket after about 30 minutes to an hour of operation.
Also, maintain at least 18" of clear air space around the entire unit.
In addition, if you're using this in a basement Ambient air temperature at floor level is between 40 - 60 degrees. dehumidifiers do not work well between those temperatures Unless, you have a Low Temp Unit). This applies mainly to where the air temperature at floor level is colder than at shoulder level
in basement applications . Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
Hope this helped you to further troubleshoot and solve the problem. Please let me know.
Jul 11, 2011 | Kenmore 54501 Dehumidifier
Dehumidifier is running but noy collecting any water from a very admp basement
Shannon - The basic things that cause this problem are easy to troubleshoot and solve.
1. The humidity extraction level is set to HIGH. Lower it to 35% or less.
2. The air intake filter is dirty or clogged. Remove and clean the filter following the Owner's Manual's instructions on "How to clean the filter."
3. Not enough clear air space around the unit. Maintain a minimum of 12" Clear Air Space on all 4-sides of the unit.
4. The ambient air temperature at floor level is between 40 & 60 degrees F. Since the unit is a basement, the air temperature at the floor level is colder than the air temperature at chest level. Place the unit on a sturdy table or counter, that can handle the weight of the unit, plus a full tank of water.
Hope this helps you to troubleshoot and solve the problem. Please let me know, Shannon. Thanks.
Jun 08, 2011 | Kenmore Dehumidifiers
Danby dehumidifier ddr4588ee ices up. Humidifier located in basement with temp around 60degrees. Unit is 1 1/2 years old.
According to your Owners Manual, the coils may start to frost at 60 degrees and the defrost sensor should turn ON and cycle periodically. However, the air temperature at the floor level in a basement, is colder than the air temperature by 5 to 8 degrees. So this may be causing the problem. In addition, if the air intake filter is dirty or clogged, the unit has to strain to keep up and will not function as it should.
If the unit is totally iced up, turn the unit Off and unplug it from the wall outlet. Allow is to thaw completely before attempting to clean the filter. You may want to put some old towels under it while it thaws. Once it's thawed, move it to a bathroom that has a shower. Plug it it in and set the humidity level at 45%. Turn the shower ON at a Medium hot temperature (enough to generate steam) and as you exit the batroom, close the door. DO NOT operate the bathroom's exhaust fan. Allow the unit to operate for 15 to 20 minutes, before returning to the bathroom. Then turn the shower OFF and check the unit for any frost and the amount of water collected in the bucket. If there is no frost on the unit and there's water in the bucket the unit is operating properly.
When you move it back to the basement, place it up off the floor on something sturdy, that can hold the weight and not be bothered by the vibration of the unit, when it's running. (ie a work bench, a counter top, etc.) Operate the unit as you normally do and monitor it for frost or icing up. And, whether or not the defrost sensor is cycling as it should. If you get no frost or just minor frost, it was the air temperature at the floor level, that was causing the problem.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Danby DDR4588EE Dehumidifier
Compressor sounds as if its on, the fan is on, but water is not extrated from the air
If the room air is less than the set air then there is no water in the bucket because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
In addition, check to see if the air filter is dirty and/or blocked. Also, the room temperature might be too low, (below 15.5 C/ 60F) and finally, check to make sure that there is no obstruction to the unit, that might be causing poor airflow circulation.
I hope this helps you to troubleshoot and solve the problem.
Apr 28, 2011 | DeLonghi DE500P Dehumidifier
My Goldstar dehumidifier model DH304 runs,but fails to pick up any water
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
Other things that can cause problems: 1.Check to see if the air filter is dirty and/or blocked. 2. The room temperature might be too low, (below 60 degrees Fahrenheit ) 3. Check to make sure that there is no obstruction to the unit that might be causing poor airflow circulation.
Hope this helps you to troubleshoot & solve the problem.
Apr 28, 2011 | Goldstar DH304 Dehumidifier
The unit turns on and sounds like it is running,
Your coil temperature has to be below the dewpoint of the air in the basement to remove the moisture. If you can set the temperature lower or the fan speed lower it will help.
Aug 08, 2009 | Whirlpool AD40DSL Dehumidifier
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Heats up basement
Dehumidifiers and how they work
Heat pump dehumidifiers
Dehumidifiers use a heat pump (similar to an air conditioner's heat pump) or chemical adsorbents to remove moisture from the air without cooling the air.
A heat pump dehumidifier uses a fan to draw indoor air over a heat exchange coil. The coil is almost freezing. The water in the air condenses on the coil and is drained. A second heat exchange coil reheats the air, which the dehumidifier exhausts into the room.
A heat pump dehumidifier dumps heat lost from the compressor and fan motors into the air. It returns to the indoor air the heat generated by the dehumidifier turning water vapour to liquid. I got this off the internet
Jun 24, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
143 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
