What do I do when the automatic door on my seinna xl doesn't close
The automatic door suddenly doesn't close when I push the button. It worked all day with no problem. now all of a sudden it will not close all the way.
i got problem with my sliding door toyota seinna 2006, when i push control button from inside, the door can not move and stuck, if i use with hand to pull the handle it is working, it is mean from out side. can you tell me the solution, thank you.
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
The drawer often stops working when it is abruptly stopped while
opening and forced closed or vice-versa. To fix, simply do the
following: 1) Push the draw all the way closed 2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears. 3) Hold the Start Button until the time reappears in the display. 4) Repeat steps 2 & 3 three more times 5) Unplug the Microwave for 30 minutes. The
drawer is now reset. The drawer will now open electronically
(automatically) either by pushing the open button on the panel or by
pulling the drawer handle slightly.
both the rear passenger side wont unlock ???? How many doors are on the passenger side ? Or both back doors don't unlock ?
Two relays lock / unlock the back door's Not the lift gate . The BCM controls the relay's . The relay's are located in the rear fuse box . Under back seat .
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
If it stops in roughly the same spot every time, and won't respond after it has stopped, it sounds like a broken wire. It is likely losing its electrical current to run the motor. It should be right where the track bends when the door has stopped. Check for loose or frayed wiring inside the flexible plastic track just below the door. The wires will often wear after being bent over and over again. If you find a broken bit of wire, cut out that section and splice in a new length of wire. Be sure you do a good job splicing, or you may end up with the same issue again soon. I am not a mechanic by any means, this just makes sense to me, and I'm considering buying an 01 town and country with this issue, which is why I'm on this site to begin with. Best of luck -
