Question about GE JASHO97985 Mouse
Wireless mouse not working
Do I have to change settings on my laptop to be able to use a wireless mouse? I it "plugged" in and it says it is working properly.
  • naedog Jul 05, 2008
    i have updated my software and now my mouse no longer works but when i
    go into the control panel it tells me it is connected and working
    properly. i have un installed and reinstalled and it still does
    not respond
    Problem Solver:
  • 11 Answers
1. have you reset the connection between it and the transmitter? There will be a button to press [at the same time] on both.
2. Is the transmitter close enough to the mouse or is there a barrier between it and mouse?
3. have you tried start>settings>control panel>mouse.pointer options? maybe it is too fast/slow etc Have a play with those options.
4. If it is not these maybe you have a virus????
5. Or it is a dud?
Posted on Nov 10, 2007
3 Suggested Answers
kpenguin
  • 35 Answers
SOURCE: MICROSOFT WIRELESS MOUSE FOR LAPTOP DOESN'T WORK
You probably have to "connect" the mouse to the wireless connector.
Usually under there is a "Connet" button on the button side of the mouse. Press and hold this button for three seconds.
This should sync the mouse with the wireless connector.
Posted on May 16, 2008
SOURCE: spectra wireless optical mouse KT4092
I have the same mouse. What you have to do is first power off the mouse, then push on the green-lit button on the transmitter that you plug into your USB. (It doesn't feel too much like a button but you will see that it starts flashing.) Hold it down for about 15 seconds. Then power on your mouse and you will see that it should start working. I was frustrated too but got mine working.
Posted on Apr 04, 2008
I have sony wireless keyboard and mouse. how can it work with other computer
It is wireless probably because there is a small usb dongle plugged into your laptop or it is blue tooth/wifi. It will possibly work with other machines if you use the dongle or pair the blue tooth or set up the wifi.
Jan 15, 2014 | Sony VAIO 15.5 LCD, Core i5 Laptop Bundle...
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
Targus wireless mouse stopped working; plugged in and has new battery
Check in another system. If the problem persists, change the mouse. Choose Logitech
Jan 19, 2013 | HP Pavilion Computers & Internet
Installing wireless mouse on Windows 7 Laptop
connect to the internet with your laptop and then plug in your mouse,windows 7 will automatically find the driver for you :)
Mar 07, 2011 | Computers & Internet
I have a Dynex Wireless Optical Mouse (Model No. DX=PWLMSE) and it works when I plug it into my netbook. When I try to use it with my laptop (Gateway), the cursor does not move. I have tried to use the...
On some computers, the mouse will work as soon as it is plugged in, while on others you'll need to manually set the connection. To do this, plug the USB receiver into the computer, then press the Connect button on the receiver. Once the lights start flashing, press the Connect button on the bottom of the mouse. (Make sure the mouse is turned on first.) It should now make the connection.
Hope that helps!
Sep 09, 2010 | Dynex Wireless Optical Mouse
Just changed batteries in my wireless mouse.
there will be a button on your mouse. Press it to sync the settings with your laptop and it should start to work.
or else
click start
right click my computer
properties
hardware
device manager
?mouse and keyboard
scan for hardware changes
Feb 26, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My wireless mouse is plugged in and on but the mouse won,t work i put new batteries in
Some wireless mouses and keyboards come with a disk. Did yours? If so, install it. You can also try to configure your computer to use the wireless mouse. For windows vista, go to --- Control panel>hardware and sound--- there you can change your mouse and keyboard settings.... hope this helps
Jan 02, 2010 | Toshiba Satellite A135-S2276 Notebook
Wireless mouse
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Check to make sure they are set properly.
Hope this helps. Bud
Jan 01, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Wireless mouse intermittent
try going into your control panel, go mouse/ settings change your mouse settings and get some air for computers clean everything on the mouse
May 18, 2017 | HP Wireless Optical Mouse
My mouse stopped working
there is a reset (or set) button on your mouse
press that one.
if its not working yet then just unplug the USB (wireless adapter) and plug it back in
that should be it
cheers
Sep 04, 2008 | Dynex Wireless Optical Laptop Mouse
GE JASHO97985 Mouse Logo
257 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
