Pantech Link P7040 Logo
A
Anonymous Posted on Jul 26, 2014
Net10 apn settings
I need internet connectivity on my old pantech7040. MMS would be nice too.
1 Related Answer
Anonymous
  • 1285 Answers
  • Posted on Jul 05, 2010
SOURCE: need mms setting and internet for tmobile
the info you need is here
(its not your cell, but the settings is what you are looking for)
Whats the apn for a verizon galaxy s7, for life wireless
Here are the settings I found: APN Name Verizon APN vzwinternet Proxy Port Username Password Server MMSC http://mms.vtext.com/servlets/mms MMS Proxy MMS Port MCC MNC Authentication Type APN Type internet+mms APN Protocol APN Roaming Protocol Bearer MVNO Type Alternate Settings APN Name Verizon APN internet Proxy Port Username Password Server MMSC http://mms.vtext.com/servlets/mms MMS Proxy MMS Port MCC MNC Authentication Type APN Type internet+mms APN Protocol APN Roaming Protocol Bearer MVNO Type
2answers
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
1helpful
How can I make apn settings?
NET10 operates on either the T-mobile network or AT&T network here are the APN setting for both carriers:
Net10 AT&T APN service
If the one you are running on is AT&T, please enter the following values on the APN:
APN: tfdata
MMSC: http://mms-tf.net
MMS proxy: mms3.tracfone.com
MMS port: 80
Any fields not noted above should be left blank
Net10 T-Mobile APN service
If on the other hand your net 10 service is based on T-Mobile network, use these values instead:
APN: wap.tracfone
MMSC: http://mms.tracfone.com
MMS proxy: Leave in blank
MMS port: 8080
To set the APN go to Settings>More>Mobile networks>Access Point Names>Menu>New
How do I find apn settings for lg g2 on net 10 sim
1. Hit All Settings button
2 Under Networks tab choose Tethering & Networks at very bottom
3. Choose "Mobile Networks"
4.Choose "Access Point Names"
5. Hit settings key, choose "New APN"
6. Settings are as Follows (if blank leave it as is):
APN: tfdata
Proxy:
Port:
Username:
Password:
MMS port: 80
MCC: 310
MNC: 410
Authentication type:
APN type: default,mms,supl,hipri,fota
7. Hit settings key choose Save
8. Now choose Net10
9. Restart phone and your all set!
Apn net10 problems
I found these settings, not sure if they will work but you can give them a try.
Enter these settings
Apn: tfdata
Port: 80
Mmsc: http://mms-tf.net
Mms proxy: mms3.tracfone.com
Mms port:80
or :
APN: wap.tracfone
Proxy: att2.tracfone.com
Port: 80
UN: EMPTY
PW: EMPTY
Server: EMPTY
MMSC: http://mmsc.cingular.com
MMS Proxy: att2.tracfone.com
MMS Port: 80
MCC: 310
MNC: 410
Auth Type: EMPTY
APN Type: internet+mms+supl
and finally, you can try the settings posted in this link, they may help.
http://forums.wpcentral.com/windows-phone-7/226267-net10-apn-settings-really-work.html#post1987074
Lewis
Unlock net10
I've never used a BB storm 9530, but if phone/sms is working but data is not you do not have the APN settings for Net10. The correct APN Settings are here: http://apn-settings.com/net10-apn-settings-easy-setup-guide/
Can't send or recieve MMS on Net10
With net10 it tells you clear as day on the step by step activation process on the web page that net10 does not support multi media messages. You will need to download a third party messaging app to send and recieve or use the email app.
Top Pantech Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
