Question about Coleman Heating & Cooling
Location of reset switch
Where do i find the reset switch for an old duo therm brisk air air conditioner? I had two things running at the same time and the air shut off,
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
The only reset switch on the air conditioners if the actual 120Volt Circuit Breaker located in your coaches breaker panel. Locations vary depending on unit type. If that does not work, you have other issues.
Posted on Jun 30, 2009
How do I Wire a duo-therm RV heat pump
see wiring on panel make sure dip switches correct
Feb 26, 2015 | Dometic 459196 Duo-Therm Brisk Air...
What is wrong with my RV ac unit ?
Low freon switch prevent the compressor from running when there is not enough freon to carry the oil to lubricate it. There is almost always enough pressure to start it but as soon as it's running low pressure drops and the compressor stops.
Aug 04, 2014 | Dometic 457915 Duo Therm Brisk Air...
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Rooftop a/c not cooling as well as it used to.
How old is this unit? In the Duo-Therm Brisk Air Models, they were notorious for a small leak in the capillary tube that runs into the evaporator part of the AC. There are two small tubes that are run together, take the top off of the evaporator coil and pull the lines apart gently. Look for noticeable signs of leaking in the area. If the lines have been looking or look like they have rubbed together for an extended period of time, you need to have someone replace the lines or buy a new air conditioner. I would price both before committing to either one. Hope this helps.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
376 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
