Question about Kenmore 53542 / 53544 Side by Side Refrigerator
The frame around the doors are burning hot - Kenmore 53542 / 53544 Side by Side Refrigerator
  • 40 Answers
It is normal when the compressor is on.As it prevents condensation at the sides.It depends to the ambient temperture and the warm load inside the refrigerator.as this will lead to higher run times means hot gas is flowing around the corners.
Posted on Jul 01, 2009
Door frame really hot. What's wrong?what do I trouble shoot?
It is common for manufactures to either install a heater around the freezer door frame or run a loop of the condenser coils around the frame. If it is very hot I suspect that it is a condenser loop. Try cleaning the coils under or in back of the refrigerator. they may be clogged or the cooling fan is stalled and the compressor is working hard to cool the coils. this is the most common reason. the other cause id poor refrigeration. and the cool of the freezer isn't compensating for the heat of the coils.
Jul 24, 2014 | Refrigerators
LG gc-151sa fridge works on. But door frame get hot what is this
Door frame around the freezer compartment is heated to prevent condensation around the door frame during high humidity conditions.
During times that Air Conditioning Or Heating are used in the house, the relative humidity is low and the "energy savings" switch may be turned on - that will turn the heater OFF.
WARNING: if you accumulate sweat around the door frame, you must turn the heat back on to prevent rust and damage to door gasket
Jul 21, 2014 | Refrigerators
The top & sides of freezer outer housing getting quiet hot,but only near the door,ps-have the red light alert & rest seems ok,so going to try the defrost stuff.
If you remove the rear panel inside the freezer and examine the evaporator while running you will most times see a few rows of the evaporator with clear ice and the rest will be sweating water droplets. That is what a leak in the Freon will cause and look like. When the door frame gets hot it is sometimes caused by a defective condenser fan or blocked air flow and also reduce cooling. Warm is normal around door frame because you have hot gas flowing there to reduce sweating around doors. I will be here to answer any questions you may have, Thanks Sea Breeze
Aug 22, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
The door frame of my fridge is really hot. What
Your condenser fan, which is underneath around back behind the cardboard backing, is probably not running. It should run when the compressor runs. The compressor is also in the same area . Test the fan- http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 02, 2009 | Refrigerators
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator gets extra hot on top and side
The only thing that I can think of that would cause this is heat strips that are placed around the door frames to prevent moisture from forming around the doors. The way you have explain what is happening is an indication that the strips are out of control. If you can find the model number located on the bottom of the fresh food compartment door frame behind door get that for me. The problem is unsafe and should have your full attention until resolved. The parts cannot be replaced and can short out. If you have a local dealer or someone to talk to about the problem would be a good
idea. If you can find model number let me know. The model number above your post appears to be incorrect. Thank You Sea Breeze
May 24, 2009 | Whirlpool GD2SHGX Refrigerator
Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Kenmoore refridgator side by side rubber gets hot
If you have a model with an energy saver switch turn the switch on. This reduces the heat to the mullion heater built into the door frame.
The door frame heater is used to prevent moisture from condensing on the seal surface around the door and acts as a thermal break between the outside and temperature inside the refrigerator.
May 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
190 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
