Question about Nikon Speedlight SB-600 TTL Flash
I had two Nikon 600 speedlights in my bag in the closet for about six weeks. Batteries in. I went to set up a shot yesterdsy and both have dead batteries. I put new batteries into one, if worked instantly. The other doesn't work at all. I've checked all the batteries. I press the button, nothing happens.
I had the same problem, but with another symptom. The batteries with the positive terminal "up" were distinctly lower in the flash body than the other two. One suggestion was to bend up the contacts, but it appears that the problem is in the flash body, so instead I just put in "shims." I just folded up some aluminum foil and dropped it into the problem areas. Worked great - it'll irritate me every time I change batteries, but it's pretty much no risk, unless someone points out something I'm missing. I had the same problem with a Garmin eTrex GPS, and the same solution has worked for years. Of course, cleaning the terminals is certainly the first thing to try...
Posted on Aug 02, 2009
Clean terminal in battery compartment.
Posted on Jul 25, 2009
Bought a Nikon Speedlight SB-600 in August. Tested the flash and it fired ok. I took out the flash a few days ago to use at a graduation and the "ready" light did not come on. Consequently it did...
Hi grwcamp, Sorry to hear about it not working at the graduation. Are in the correct position (I am sure you did but, we must start someplace). Look inside, see if there is battery acid in there.
If with new/fresh batteries it still does not work call Nikon. You have a warranty on it so it should be covered.
Nikon digital 1-800-645-6689
Dec 04, 2010 | Nikon Speedlight SB-600 TTL Flash
SB-600 flash suddenly dead. Found some early corrosion on the AA batteries. What happened? Repairable?
Hi degossman, Corrosion is sometimes a fix us users can do. Other times it must go in for repair. What happens is the corrosion may leak past the point we can see in to the internals of the housing eating out wiring.
Nov 30, 2010 | Nikon Speedlight SB-600 TTL Flash
I did not drop it. But it stopped turning on.
Are you sure the batteries are good and installed correctly?
Jul 06, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon SB-600
seems like the batteries have gone dead. Replace the batteries. Get a set of good capacity rechargeable NiMH batteries (I recommend Sanyo Eneloop). Also try cleaning the battery and flash contact points with an eraser.
Feb 03, 2009 | Nikon Speedlight SB-600 TTL Flash
Flash gun failed
(1) THE FUSE ON THE MAIN BOARD IS OPEN .
(2) BATTERIES ARE DEFECTIVE
(3) CHECK BATTERY CONTCATS BEING BENT
Berrie Smith Camera Repair
bbmw@bellsouth.net
770-312-0719
Aug 05, 2008 | Nikon Speedlight SB-600 TTL Flash
SB 600 Not resetting...
my sb 600 speedlight won't turn on. Do I need to reset it? It has fresh batteries. Never been dropped
Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Problem with SB-600!!!!
Batteries may have leaked. Open battery chamber and clean ---especially the contacts situated at the bottom -- with pencil erazor. Blow out any loose bits and with new batteries try to switch the unit on.
Sep 18, 2007 | Nikon Speedlight SB-600 TTL Flash
Fried Unit
Mixing the batteries should not have damaged the flash. More likely the smoke came from the odd battery.
Aug 09, 2006 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
261 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
