Question about Integra DTR-5.2 Receiver
Low to no volume output from Integra DTR-5.2 receiver
I have an Integra DTR-5.2 receiver. For the tape deck input, I hear nothing coming out of the speakers until I crank the volume all the way up, and then the sound is very faint. I get no sound from the DVD player connected to the receiver, nor from the CD player. All cables are connected properly, and all inputs are set up correctly. I also tested the speaker cables with another amp, and they work fine. I opened the unit and checked the fuse; it's not blown. I tried different volume settings for the speakers to no avail. What is going on? Please help.
  • 1 more comment
  • Anonymous Mar 17, 2014
    no sound
  • Anonymous Mar 31, 2014
    I have no volume, slight popping
  • tom chandler
    tom chandler Sep 15, 2014
    I have an Integra 40.3 and I had the same problem. I found the receiver has a factory problem. The company know about it. I would contact a service provider.
    Problem Solver:
  • 9 Answers
Most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
I have a Pioneer VSX-D308 reciever and I have a EQ. How do I hook it up to this reciever?
I only know of one way to do this and here it is:
1. Plug your tape deck's output (cassette or R2R) into the EQ's "Line In".
2. Plug the EQ's "Line Out" into the Receiver's "Tape 1 Input".
3. Now plug the Receivers "Tape 1 Output" into the Tape Player's "Line In".
4. You have now made an "FX loop" for the Tape Deck. Now you just have to put the Tape Deck on "Tape Monitor".....put the Receiver on "FM"..... and turn on your favorite FM station and you will hear the FM Receiver THROUGH the tape deck's "Monitor Send" AND the EQ.............set EQ to taste....... and BINGO.......DONE!
Enjoy,
SKYNETRP
Jun 09, 2011 | Pioneer VSX-D308 Receiver
I have a Technics Double Cassette Deck RS-TR212. On the rear it has Output and Input connections. Output goes off to the Amplifier. Can the Input be used to record or play from a record Turntable? I have...
your receiver has (or should have) input and output connections,, your turntable needs to be hooked to the receiver,, then with the output cables that feed your cassette player you need to go, in to out and out to in ( receiver output to the input of the tape player, and out of the tape player to the in on the receiver, while playing a record if you hit record on the tape player it will record the record, depending on the receiver it will show you the meter readings for either the in or out,, they vary
Apr 11, 2011 | Audio Players & Recorders
I need manuals for hooking up my fisher stereo system model ca 871 amp fm 871 tuner cr-w890 tape deck eq 867 eq can not find manuals
I can't even find a reliable picture of the amp but it's not rocket science.
The Tuner output goes to, say, FM or Aux on the am, anything BUT Phono, which is ONLY for a turntable.
The EQ output goes to the first available Tape In; Input Comes from the same Tape Out. Select that tape function to engage it in line with any source and the downstream electronics (second tape, tone, volume, speakers).
The tape deck output goes to Tape In; Input comes from Tape Out. If there is not a second tape loop on the amp, nest the Tape Deck into the EQ's Tape loop. They always have at least one to replace the one they use. Select THAT tape function to engage it in line with any source and the downstream electronics.
Mar 13, 2011 | Audio Players & Recorders
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
No output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
May 11, 2009 | Integra DTR-8.3 Receiver
No audio on any channel, even in audio setup mode, no audio headp
If you have any of its sound outputs connected to a TV or tape deck do they get the signal? If so, then we know there is sound processing somewhere inside the unit but not emerging to anyplace that requires amplification.
A quick basic check would be to tune an FM station, run an RCA cable pair from the audio output for a tape deck (see the picture at the link) to an analog audio input on your TV. Select that input on the TV and you shouls hear the FM station, or anything the receiver is configured to play. If it's silent then there is no audio signal circulating in the receiver to get out to the amplifiers.
http://www.onkyousa.com/images/hookup/TX-SR803/detail_tapedeck.jpg
Check to make sure Multi-Channel input is not selected unless that is what you're listening to as it bypasses all other sources analog and digital EXCEPT the tape; and check any Mute or Zone Controls, too.
If you hear the program on the TV but not through any attached speakers, then the amplifiers are all disabled for some reason. The click I asked about before... when you turn it on does it get a click about 5 seconds later. That would be the protection circuitry turning OFF to allow the amplifiers to function.
I notice it has a Tape function. Make sure it isn't selected as it assumes a tape deck or processor is attached and will only play back what would be coming FROM the tape deck or processor. On my Pioneer receiver it also disables any digital signal processing.
Sometimes when I'm watching TV with the remote on the seat someone moves and something bad happens. It's always some unfamiliar button that gets touched unintentionally. Look over the remote for things like MUTE, Multi-CH, Tape.
Apr 02, 2009 | Onkyo TX-SR803 Receiver
Volume control unstable
You may have an over heating problem as it the Integra has anautomatic cut out. The unit generates a huge amount of heat and needs to be positioned in a very well ventilated position.
Linian
Dec 11, 2007 | Integra DTR-5.1 Receiver
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Integra DTR-5.2 Receiver Logo
621 people viewed this question
Top Integra Audio Players & Recorders Experts
Rob Villi
Level 1 Expert
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
