Question about Logitech Attack 3 Joystick
Problems with vista
Hey, i need help...im trying to use my joystick with flight simulator and all you can do is configure the buttons but not the axis and throttles.... i using windows vista
  • 33 Answers
It is better to use windows xp!!! if you are using vista find the name of that joystick!! does your joystick have cd driver?just install the driver!!!
Posted on Jun 30, 2009
I am playing Flight Simulator X Gold Edition. On my Logitech Attack 3 joystick, what is the throttle control level number? Please help!
I have the same stick, the throttles are actioned by the little levers in front of you at the bottom of the stick, I dont quite understand what you mean by level number...
all you have to do is configure them in the configuration panel of the flight simulator, I use same simulator for practice.
Aug 19, 2011 | Logitech Attack 3 Joystick
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
I have Microsoft Flight Simulator X and a Satek X52 flight control, however I have problems with the throttle on all aircraft. I have to use the F-4 key - can you help?
You need to assign the throttle function correctly WITHIN FSX settings area itself. Also calibrate the joystick in windows first. If you are not familiar with assigning FSX functions to your joystick, check the Learning Center section within FSX for step-by-step details.
Feb 24, 2010 | Microsoft Flight Simulator X for Windows
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
Joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
Mar 22, 2009 | Logitech Attack 3 Joystick
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Jun 25, 2008 | Microsoft SideWinder Precision Pro 2.0...
Saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Apr 11, 2008 | Saitek Aviator AV8R Joystick
Trying to Taxi
Your joystick's drivers may not be installed or installed correctly. I reccommend you go to your joystick manufacturer's website and try to find drivers for your joystick.
The flight simulator (I'm guessing that's what it is) may also not be configured correctly to use a joystick. Check in the game options to make sure that you do have joystick support enabled.
Apr 09, 2008 | Saitek (PS28) Joystick, Throttle
Logitech Attack 3 Joystick Logo
307 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
