Question about Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
How do you set the time? Its not moving> How do
How do I start the clock? Its not moving? Do I pull the dial out 1 click?
  • bryankid Jun 30, 2009
    There is not reset button. This timer is an intermatic T101. I have it pulled outward but it seems like its not moving. When I pull it out ward I can set the time but I can't figure out how to start it so it will go off at the times i selected. Thanks,
  • 864 Answers
To set the time pull the dial out toward the front and rotate it until the current time is lined up with the "time of day arrow". If the dial is not turning to keep the correct time, press the reset button at the upper right corner of the panel.
Posted on Jun 30, 2009
  • John Morganti Jun 30, 2009
    Did you install the clips (they are called dogs) at the times that you want the clock to go on and off? They should be black and white or brass and silver. One is for OFF and the other is for ON. Put the dogs on the edge of the dial and screw them tight. As the dial rotates the dogs will trip the switch that turns on and off. There is a lever below the dial that you can also to flip manually to On and Off to check operation.
How do I set T101 intermatic T101 timer to 7:30 PM
PROGRAMMING INSTRUCTIONS 1. TO SET "ON" AND "OFF" TIMES: Hold trippers against edge of CLOCKDIAL, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A. 2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
http://www.intermatic.com/-/media/inriver/10162-9164.ashx/T101-Instructions-EN
Mar 23, 2017 | Intermatic Hardware & Accessories
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
I can not get the timer to come on at the correct time. The dark colors are PM and the White background is white. But AM is from 6:30 to 6:30. I want the lights to come on at 4:30 to 10PM. I have tried...
Your timer could be broken.
But let's review.
Override set atTimer on > correct
When override is moved other direction, then lamp turns on.
Lamp fixture is turned on
Bulb is good
Receptacle has power
You tied timer on different lamp at a different receptacle.
Dial rotates with passing time, which indicates that clock motor is functioning
Dial does not get stuck during rotation, and makes complete 24 hour circuit in 24 hours, indicating that clock motor is not weak.
Segments up or down for timer functions >> here's what to do: pull up some segments. Manually rotate timer dial clockwise.
The lights will turn on-off as you rotate dial manually.
That will confirm if up or down is correct position of segments.
If everything above checks out, timer should work.
If timer is defective, exchange for another one.
I test these timers and 4-6% arrive defective. Most last one or two seasons and then they quit.
Some last years.
But timers today are priced low enough.
Dec 14, 2010 | First Alert 24 Hour Timers - 2 For The...
How do i turn off demo mode? And set the clock?
  • Press and hold (SEL) button
  • Then turn the control dial to set "Demo/Link" to off
  • Setting the clock
  • Press number button 4 (Clock). "Clock Hr" (hour) appears. Then, turn the control dial to adjust the hour.
  • Press the >>' /\ (fast forward button) to select "Clock Min" (minute). Then, turn the control dial to adjust the minute.
  • Press the >>' /\ (fast forward button) to select "24H/12H". Then, turn the control dial to select "12Hours" or "24 Hours" time display mode.
  • Exit from setting by pressing the (SEL) Button
Hope that helps, don't forget to vote.
Nov 16, 2010 | JVC KD-G820 CD Player
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Hello I lost my instructions for theej351c, can you help?
1. Move control lever to OFF-CLEAR for at least 5 seconds; red indicator light will go
off, and all previous time settings will be cleared from memory. (If timer fails to set, leave in off
position for 15 minutes.)
2. Move lever to ON. RED INDICATOR will start FLASHING.
3. Check a clock; then rotate time dial clockwise at least one click, stopping at the half
hour nearest to present time. NOTE: When rotating time dial, do NOT accidentally PRESS at
the same time. (While rotating dial, keep pressure, pulling out on the dial to avoid accidentally
setting an incorrect time.)
4. Press pushbutton once to enter present time. RED INDICATOR will go OFF, present
time has now been recorded.
5. Rotate time dial clockwise to desired ON time; RED light will PULSE momentarily
with each click.
6. Press pushbutton to enter ON time; controlled light(s) will turn on.
7. Rotate dial to desired OFF time.
8. Press pushbutton to enter OFF time; controlled light(s) will now be off.
9. Repeat Steps 5-8 for each addition ON/OFF period.
10. Continue to rotate time dial for at least 24 hours from the first ON time to complete
this program, at which time the RED INDICATOR light will come ON and stay ON,
indicating timer is in AUTOMATIC mode. NOTE: Dial does not rotate automatically
after setting to indicate time of day.
Oct 26, 2009 | Intermatic Programmable 24 Wall Switch...
Just installed a T101. Unit will not switch to on position works perfectly to off position. Can it be adjusted.
Yes.
Programming Instructions for the Intermatic T101 - 24 Hr. Dial Time Switch:
1. TO SET ON AND OFF TIMES: Hold trippers agains edge of clock-dial, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A.
Operating Instructions:
* To operate switch manually: move manual lever below clock-dial left or right as indicate by arrows (graphics) This will not efect next operation.
* In case of power failure, reset clock-dial to proper time-of-day. See Programing Instructions (top lines).
Good luck (reemmber rated this help).
Oct 23, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Cannot set time
> press and hold clock/sleep/timer button
> turn dial to set hour
> press enter button
> turn dial to set minute
> press enter button
now, your clock should be in working order! :)
Jun 17, 2009 | Sony CD Radio Cassette Boombox, CFD-E90...
Whitting and Westminster Jean luis Electronic clock
I found my own solution through trial and error. I set the dials to 12 00 and then move the dials to show just over 5 minuites to 12 ( 1155) the alarm melody start and chimes for a number ( in may case it was one.) then i moved the dial back to 1200 and then reset it again to 1155 or just over. Each time the alarm chimes an increasing number
I had the clock chime settings on the back of the clock to the middle setting (chimes on 24 hours)
I carried out this until the chime was right for the time i was working ( in my case it was 1730) so when it reached 5 chines I then set proper time and left it. The next chime was correct
Jan 09, 2009 | Seiko Mantel Clock
Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
301 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
