Home | Fisher and Paykel | GWL11 Top Load Washer | I live in the cou...
Fisher and Paykel GWL11 Top Load Washer
Problem for Fisher and Paykel GWL11 Top Load Washer
I live in the country in NC. My water is well
By sadielew2002 on Jun 30, 2009
I live in the country in NC. My water is well water. After several washings, all my whites turn dingy. I can't use bleach a lot because I have septic. To tell the truth, bleach doesn't really help
Solution #1
posted on Jul 07, 2009
Not Rated)
jsrock516
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 6509 votes
I also live in NC and experienced the same problems you describe. I tried all detergent additives along with bleach to no avail. After the rust and sediment started wrecking my appliances, I decided to install a water softener with a whole house sediment filter. It wasn't that expensive and I installed it all myself. The salt I use is Diamond Red Out salt. This not only softens the water, but completely got rid of the rust problem. Something you may consider. I've been rust free now for about 6 years.
Was this helpful?
Yes
No
Solution #2
posted on Jun 30, 2009
Not Rated)
dburns60
Rating: 85%, 83 votes
For brighter, softer, stain-free clothes, add 1/2 cup Arm and Hammer® baking soda to your regular detergent in the wash cycle, then add 3/4 cup Heinz® white vinegar to the rinse. Soak really dingy clothes for ten minutes in the baking soda-detergent mix before washing in the hottest water fabric will accept. Vinegar smells should vanish after clothes have dried. Many online voters said that this worked best.
Was this helpful?
Yes
No
Popular Solutions for Fisher and Paykel GWL11 Top
Questions and Unsolved Problems for Fisher and Paykel GWL11 Top
Do you recommend Fisher and Paykel GWL11 Top Load Washer?
Answer
Answer
My GWL11 is dripping water from a white tube on the inside of the drum. It is located under the back... (More)
Answer
washer stops in rince cycle, also drain pump stops and starts. does not drain completly. may be... (More)
Answer
Washer stops with a fault code 51. (00xxo 0xx) Sheet does not include this problem.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel GWL11 Top...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
