Question about Tomtom XL 330 Car GPS Receiver
Tom tom 130 and/or 130S
...do they have an sd slot?
The solution to TomTom freezing problems is to throw these pieces of foreign made junk in the trash. My 130 never worked since it was new because it is a cheap bottom feeder GPS full of recycled Chinese components. The trash can is the solution.
Posted on Aug 12, 2009
My tom tom one 3rd edition has frozen how can i get it working please
You can try a hard reset.
By removing the sd card and using i paper clip pushing it into the reset hole on the underside of the unit, push and hold for 15 seconds, Then switch device back on and slot your sd card back in
Apr 24, 2010 | Tomtom ONE GPS Receiver
My tom tom one has been trying to find a gps signal all day. It is asking am i i na building? it whas worked perfectly up to when i booted up this am!
Have you tried a hard reset? if not switch off the unit remove the sd card and stick i pin/clip into the small hole by the sd card slot for 15 seconds, then replace the sd card and power up.
Feb 12, 2010 | Tomtom ONE GPS Receiver
I can't get the dish to re format. Error meassage reads disk problem and a x in a red circle appears.
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
The SD card may also need formatting properly.
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Oct 11, 2009 | Tomtom ONE GPS Receiver
Tom tom will not turn on, but charge light works.
Please connect your tom tom to the power adapter first.Get a paper clip and press the reset button under the SD card slot of your tom tom.Reset button is a very small small hole at the back near the sd card slot.Keep pressing the reset button for 2mins and also press the power button till the light comes on.
This should fix the issue.Let me know if you need any more help.
Jul 08, 2009 | GPS
Where is the sd slot on tom tom one
on the bottom of unit unless its a v3 i dont think they have a slot, hence, why they are so cheap..
Jul 04, 2009 | Tomtom ONE GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Tom Tom 910 software
I don't think the Tomtom 910 has a SD card slot. Check the model # of your GPS again.
Apr 01, 2008 | Tomtom GO 910 GPS Receiver
Slot
The Slot in the base of your Tom Tom is for the SD Card. This is where your maps are stored. No SD Card no maps. Hope this helps
Nov 30, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom1 memory
The way the TomTom One works (unfortunately) is that it reads either from the SD slot of from internal memory, but not both. So you can't have the SD act as supplemental memory. I had the same problem and was pretty peeved about it. You would have to spring for a more expensive model to get this feature :S
Oct 04, 2007 | GPS
Tomtom XL 330 Car GPS Receiver Logo
184 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
