Serial number 23267736
SOURCE: When was a Marlin model 60, serial number 15457098 manufactured?
Go to marlinfirearms.com . Click on Customer Support, and pose your question. There is nothing like going to the source.
SOURCE: How to determine the model and serial number of a marlin 22 rifle?
this is copied from a site, the web address is pasted below.
The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
also if you find serial # you may find more info here.
http://oldguns.net/sn_php/marlinlookup.php
From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
1985.
According to Marlin's website, take the first two digits (15) away from 2000, in order to find the year of manufacturing. Ironically enough, mine is from the same year...15387573
Serial number "U" is 1961
The following table can be used to date the year of manufacture of a Marlin 336. It is also valid for determining most other Marlin firearm build dates from 1946 to the present.
Marlin year of manufacture maybe determined from the following table of letter/numeral prefixs to the serial number:
Date Prefix(s) 1946 C 1947 D 1948 E 1949 F 1950 G 1951 H 1952 J 1953 K 1954 L 1955 M Date Prefix(s) 1956 N 1957 P 1958 R 1959 S 1960 T 1961 U 1962 V 1963 W 1964 Y, Z 1965 AA Date Prefix(s) 1966 AB 1967 AC 1968 AD, 68 1969 69 1970 70 1971 71 1972 72
