Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
How do I put Jabra BT 135 in Discovery mode? - Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
Turn the device on and continue holding the power on button until the light stays solid. That puts it in discovery mode.
Pair it with your device.
It will probably also ask you for the password to the bluetooth headset (mine did). The default is 0000.
Posted on Nov 01, 2009
Press the button for 2-3 seconds when the light stops blinking and constantly stays on .. thats the Discovery mode
Posted on Jul 14, 2009
Hi' i got a iphone 3g and a jabra bt135 headset but cant connect can someone plz help me!!!!
Posted on Jul 22, 2009
How do I pair it with my phone? i lost the manual If I just turn it on, it my cell doesn't seem to find it. It says to put the Jabra in discovery mode. How do I do that? Also, do you know how I can...
Christine,
To put the Jabra in discovery mode, turn it on and hold the answer/end button for five seconds until the bluetooth light starts flashing and it announces "pairing mode." Then connect with your cellphone!
You can order a new charger for your car/computer from this link:
http://www.buyjabra.com/US/accessories/universal-charging-kit-car-usb-136.html
Or, for your wall from this link:
http://www.buyjabra.com/US/accessories/us-wall-charger-for-bt530-jabra-halo-144.html
Best of luck!
- Zach
Mar 05, 2011 | Jabra Cruiser InCar Speakerphone Black
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
Feb 26, 2011 | Jabra BT2080 Bluetooth Headset
Someone change my passkey of jabra bt2070 how i get it
hello first i would like to know if your phone is paired with ur bt device if it is and it is asking for your pin code again most pin codes for manufactures are as follows 0000,9999,1111,or 1234.hope this is the answer you are looking for..now if your device is not connected you need to reconnect the device to your phone ,follow your cell manufactures procedures for connecting your bt device and make sure u set your bt device to discovery mode,then when it asks for the pin code enter one from above most are 0000 but the odd time one of the other codes is required...hope this helps
Feb 22, 2011 | Jabra Bluetooth Headset - BT2070
I am trying to pair my Jabra BT 4051 with my iPhone 3G. I had it paired with my 1st iPhone, which was just replaced. it goes into the "searching" mode, but never seems to find it?
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 11, 2010 | Jabra BT4051 Bluetooth Headset
Cannot get my new Iphone 4 to pair with my Jabra cruiser bluetooth. I am in the setting and have the phone looking for the the Jabra but can't find it?
Nov 22, 2010 | Jabra Cruiser InCar Speakerphone Black
This is my first bluetooth and I'm having a problem getting my Jabra BT125 into discovery mode
The Jabra goes into discovery mode when the unit is off, and the power button is pressed for ten seconds, which passes the five second power on time.
At ten seconds the unit lights constant to state discovery mode is on.
See the manual on Pairing:
To download the PDF of the Manual click here. This is page 6.
Dec 12, 2009 | Jabra BT125 Headset
I'm having trouble getting my jabra bluetooth in discovery mode
Hold down the power button until it becomes a steady blue light. This should put it in discovery mode
Oct 20, 2009 | Jabra BT125 Headset
I'm having trouble getting my Jabra bluetooth in discovery mode.
Hold down the power button until you get a steady blue light. This should put it in discovery mode
Oct 20, 2009 | Jabra VBT185Z Bluetooth Headset
Reseting Jabra Bluetooth
Jabra headsets sometimes have a different way of being put into discovery mode. Most headsets just have you press and hold the big call button on it. Some jabra headsets require you to JUST hold down both volume buttons and some other jabra headsets require you to hold down ALL buttons on the headset to put it in discovery mode (or pairing mode as they sometimes call it)
Try of those combinations ... The light will stay solid when it's in discovery mode... Once the light is solid THEN have the EnV search for headsets.
hope this helps
Dec 18, 2007 | LG enV VX9900 Cellular Phone
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
2,384 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
