Question about Carrier 38CKC036 Air Conditioner
My air condition heater
When i put on the heater on auto it don't come on so i put it on fan it come on blowning out cool air
  • 49 Answers
Auto and on only controls your blower inside the home. More info is needed to determine if you have a gas furnace, electric furnace or a heat pump system.
Posted on Nov 08, 2007
What can I do to fix both of the cooling fans don't work kia spectra 2004 manual 2.0 is overheating
fan should be a designated relay
one fan cools the engine
other fan is for air conditioning condenser
if no better
check for 12 volts to the fans
you bench test both fans to see if the spin fast enough
Apr 27, 2017 | Kia Cars & Trucks
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - Community Forums > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from
Nov 01, 2015 | Heating & Cooling
2006. Why doesn't it heat or cool?
Sounds like the fan is working but not the heating/air conditioning. These may be separate . You need to have an auto electrician look at the fault as it will need to be traced.
Check your fuses befor referring to somebody else for a diagnosis, it could be a simple fuse blown that will only cost pennies to remedy yourself
Jun 20, 2015 | Scion Cars & Trucks
How do I fix the air condition control buttons?
Well, I can't tell by your explanation if the knob stem is broken & just spinning around or if it feels normal and nothing happens.
So, I guess I would first have you check all the fuses labeled "AC" or "Heater". Might be just a blown fuse, but remember, fuses always blow for a reason. There are many things that can be causing your problem like the heater/ac fan speed relay or a broken wire, etc.
I don't how auto repair savvy you are but, Google "Mazda 3 a/c panel". You will see many things on that first page like inexpensive replacement knobs, etc. There are even several YouTube videos on how to gain access to your ac/heater control panel. There is a wealth of information there. If you are not a do-it-yourselfer, you can at least look through there to educate yourself before you take your car to someone. Being informed ahead of time is very valuable.
Nov 28, 2014 | 2006 Mazda 3
Heater not working in extreme cold weather because fan wont shut off. fan has been replace and the computer has been checked. nobody knows what is wrong
I'm making some assumptions, here.. I've been told I make too many assumptions... but, I'm assuming that you're talking about the engine cooling fan.. If I'm correct in this assumption, my guess is that you've not taken the vehicle to a good, reputable mechanic or repair shop. There are several reasons that an engine fan would not turn off, and each reason would have to come from a qualified mechanic. For example, there is a sending unit for the air conditioning system that might cause continuous running... or a sending unit in the air conditioning system that could cause the same thing. To complicate that issue, quite likely your air conditioning system purposely kicks on the engine fan any time you run your defroster. Also, your inside heater should function correctly, regardless of the engine fan running continuously. If I'm wrong on that score, then your engine has a thermostat problem "to boot"... which, by itself, could cause poor heating of the inside of the vehicle. NOW, backing up a little, if you so happen to be talking about the fan INSIDE the vehicle that is part of your heating OR air conditioning, we have a little different matter on our hands... First, some vehicles legitimately have a fan running on slow speed at ALL times.. for continuous air circulation purposes (sometimes, you can't actually hear this). Also, I might add that THIS fan running all the time should not be a problem for the heater to work properly.
Jan 03, 2014 | Cars & Trucks
Possible that the vent is getting blocked to prevent the cool air to be blown into the fridge section. So make sure that the auto defrost is working, if not check the auto defrost timer section, the fan, the heaters.
make sure that the thermostat is set to normal.
Finally shut off the fridge for 6-8 hours and see if the cooling resumes. If so the defrost section must be revisited
Oct 30, 2010 | Jenn-Air JCD2389G Side by Side...
What mode on my model hprbo7xc7 is for air
Hi, On all model stats, the mode you want for the fan to cycle off and on with the air conditioning, is cool-auto, not cool-on. With cool on, the indoor fan will continue to run all of the time. In the auto mode, it will cycle on and off.
Jun 27, 2010 | Heating & Cooling
Air conditioner is blowing hot air, it was installed 1995 , the top switch option is CONT FAN AUTO and bottom switch is HEAT OFF COOL and on the right is a dial from 10-30
First of all, what do you mean by hot air? DO YOU REALLY MEAN ROOM TEMERATURE AIR THAT JUST DOES NOT FEEL COLD? If this is a heat pump system, we need to look at it differently than if it is a gas or oil fired heater. Next, the thermostat control that says " auto"----- this actually means FAN switch to be in AUTOMATIC RUN or CONTINUOUS RUN mode. Leave it in auto mode and forget that it is there; this little switch confuses a lot of people. The dial that says 10-30 is centegrade temperature that translates to 50-87 degrees farenheit. In order to get air conditioned (cold) air, you must have thermostat fan switch on auto, the heat/off/cool switch on cool, and the 10-30 dial on 20 or 21 (68-70 f.) assuming the room temp is at least 72 degrees f. or higher. If you still do not get cold air, then there is a problem with the cooling circulation system which can be tripped circuit breaker to outside compressor unit, loss of freon refrigerant, bad control such as relay or reversing valve in outside unit, stuck heat sequencers or heat element relay that are giving you heat at the same time giving cold if it is a heatpump system. You will need a skilled service person to determine these problems. Goodluck, Macgivor
Nov 09, 2009 | Cell Phones
2002 mercury sable heater wont get hot
you have a broken or stuck temp blend door in the heater case. or the servo motor is broken. this sits on top of the heater case
Dec 02, 2008 | 2001 Mercury Sable
Carrier 38CKC036 Air Conditioner Logo
111 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
