Question about Frigidaire GLTF2940ES Front Load Washer
I have a Frigidaire GLTF2940FS1 washer that beeps and flashes ERR
I have a Frigidaire GLTF2940FS1 washer that washes fine, but when finished it just keeps beeping and flashing ERR. I have unplugged for long times and does not help. We now have to unplug between loads or get the beep all night. Is there a way to reboot the computer on this? Thanks, David
SOURCE: LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Posted on Dec 30, 2007
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Posted on Apr 27, 2008
SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
Posted on Aug 19, 2008
SOURCE: Frigidaire Affinity Washer beeps & won't spin
The drain filter is clogged. I had the same problem. There is a filter inside the "drain boot" (black) that comes from the drum to the drain pump. Mine was completely clogged with money, lint, etc..
Posted on Oct 19, 2008
  • 3 Answers
SOURCE: very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Posted on Dec 06, 2008
Gltf2940fs1 machine stopped with 1 minute left in the cycle, could it be the door latch or motor control board
I appreciate your post, friend!
Based off the information you have provided your Frigidaire washer, GLTF2940FS1, stopped with 1 minute left in your cycle. This could be a potential issue with your door latch, control board, or a miscommunication within your washer. I would recommend a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. If that does help correct your issue you may need to consult with a technician for proper diagnosis and repair. This may help you avoid any unnecessary part purchases. -Matt
Mar 11, 2015 | Frigidaire Washing Machines
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
How to put the magnet on drawer gltf294es1
Might be best to go to the assembly diagrams for your washer on this site and work out the part type and where it needs to be.
Frigidaire Washer GLTF2940FS1 Repair Parts
Sep 02, 2014 | Frigidaire Washing Machines
No water enters Frigidaire GLTF2940FS1 Washing Machine when run
You will want to contact Frigidaire and ask them the sequence.
Dec 22, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Front loader model#LTF6000E
IS it giving you an error number such E20???
Aug 04, 2008 | Frigidaire ATF6000ES Front Load Washer
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLTF2940ES Front Load Washer Logo
251 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
