Question about LG KE990 Cellular Phone
I Have Ke990, its camera is not working and memory card is not detected....what can i do? i bought it 6 months back....
  • 38 Answers
Go to the shop you brought it from this is the best thing to do really
Posted on Oct 29, 2009
Bought a sony dsc h300 camera about 2 years ago...bought a Kingston Memory card for it....what do I do now ?
Have you tried formatting the new memory card? Sony suggest you format a new card using the camera.
Supported capacity:
  • Memory Stick Duo" media: up to 64 GB
  • "Memory Stick Micro" media: up to 16 GB
  • SD card: up to 64 GB
  • microSD memory card: up to 64 GB
You may also want to check the camera's user guide to narrow down what's causing the card not being detected.
http://docs.esupport.sony.com/dvimag/2014/DSCH300_guide/en/contents/12/01/04/04.html
Jul 08, 2017 | Sony Cameras
My windows PC does not detect 1000D purchased pre used without eos disk utility and bundled softwares, is it a must to install these
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
May 08, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Hi, I have the "MEMORY
try to clean your memory card.. literally clean the copper part of the card..
then put it back.. if the same problem appears, try to place it back and remove the card until the card being detected..
Apr 30, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
This Tamron used with my Canon 1000D gives since 3 months errorcode 01 (communicationfailure between lens and body). When "off" and "on" can take one picture, then errorcode 01...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 05, 2011 | Tamron 18-200mm f/3.5-6.3 for Nikon
Sony CyberShot DSC-N2 - Unable to read memory card
Before anything else.... you must examine first if your card is not damage, How? Try to test it in the memory card readers or other camera that fit the same memory cards.
Some other cards do have lock option in the jacket of the card. Try to unlock it. After doing so reformat the memory card in to your cam.
Other option...... Some other cam do have internal memory, if you have the same, configured it out.
Oct 29, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Memory Card Slot Fault
Please take it immediately to the nearest authorized service center
Aug 24, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
Nikon D80 Memory Card Not Not Reading.
I would try another card first, before doing anything else.  If you have been using just one card for 6 months and using it a lot, it could be corrupted.   It's best to always have a back up of at least one card anyway, and they have come down in price considerably.
If my suggestion and McComijohns's don't work, I would consider taking the camera in for repair.   It is NOT a good idea to mess around too much with the inner workings of the camera.  You could cause a lot of damage and it won't be covered under your warranty.  Good luck.
Mar 31, 2008 | Nikon D80 Digital Camera with 18-135mm...
Memory card problems
take the memery card out, blow inside, & put it back in. it shouldwork.
Mar 19, 2007 | Kodak EasyShare V550 Digital Camera
LG KE990 Cellular Phone Logo
57 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
